2004 LX engine information
Tried search and google to no avail. I have a 2004 Civic LX sedan with a 5 speed.
Wondering some stock specs on my engine and transmission, if you guys know them or where I can find them. I've got quite a few miles left on warranty but once it's up I would like to do a swap to my car and hopefully turbo that setup. I run mobil 1 in the engine religiously changing at or before 5000 miles and it runs sweet as a nut and doesn't burn any oil at just under 70000. The plan is to buy a used engine that's not blown and rebuild it forged, etc and swap it and a better tranny in and install a turbo kit. Any info let me know, thanks! |
RE: 2004 LX engine information
turboing your car is a pain in the ass cause of the fuel-less return, and the only swap you can do is a K series, which are just as much of a pain and big money$$$
Really... I had no idea. I'm pretty new to the newer generation of hondas.
So there is no hope for my car? |
no please dont think there is no hope swap for a k and turbo you can make some serious power but working with your d17a1 or a2 vtec is a beast of a job
ORIGINAL: monkeydude3 Tried search and google to no avail. I have a 2004 Civic LX sedan with a 5 speed. Wondering some stock specs on my engine and transmission, if you guys know them or where I can find them. 2004 Civic LX 5 Speed Manual Engineering[/align] Engine Type: In-Line 4-Cylinder Engine Block/Cylinder Head: Aluminum-Alloy Displacement (cc): 1668 Horsepower @ rpm (SAE net): 115 @ 6100 Torque (lb.-ft. @ rpm): 110 @ 4500 Bore and Stroke (mm): 75 x 94.4 Compression Ratio: 9.5:1 Valve Train: 16-Valve SOHC Multi-Point Fuel Injection Front-Wheel Drive CARB Emissions Rating: ULEV Direct Ignition System with Immobilizer 110,000 Mile Tune-Up Interval[/align] Transmission[/align] 5-Speed Manual Transmission Gear Ratios http://www.ahm-ownerlink.com/images/...s_gryonbge.gif[/align] 1st: [/align] 3.462[/align] http://www.ahm-ownerlink.com/images/...s_gryonbge.gif[/align] 2nd: [/align] 1.870[/align] http://www.ahm-ownerlink.com/images/...s_gryonbge.gif[/align] 3rd: [/align] 1.241[/align] http://www.ahm-ownerlink.com/images/...s_gryonbge.gif[/align] 4th: [/align] 0.970[/align] http://www.ahm-ownerlink.com/images/...s_gryonbge.gif[/align] 5th: [/align] 0.711[/align] http://www.ahm-ownerlink.com/images/...s_gryonbge.gif[/align] Reverse: [/align] 3.231[/align] http://www.ahm-ownerlink.com/images/...s_gryonbge.gif[/align] Final Drive: [/align] 4.111[/align][/align][/align] EPA Mileage Estimates/Fuel Capacity*[/align] 5-Speed Manual (City/Highway): 32/38 4-Speed Automatic (City/Highway): 29/38 Crankcase (qt.): 4.4 Coolant System (qt., MT/AT): 5.3/5.2 Fuel (gal.): 13.2 Required Fuel: Regular Unleaded[/align] Exterior Measurements[/align] Wheelbase (in.): 103.1 Length (in.): 175.4 Height (in.): 56.7 Width (in.): 67.5 Track (in., front/rear): 57.8/57.8 Curb Weight (lbs., MT/AT): 2560 / 2606 Weight Distribution (%, front/rear, MT): 60/40 Weight Distribution (%, front/rear, AT): 61/39[/align] |
Nice but in the summer i can pull over 40mpg out of it... hehe
Okay... well I guess I will do a search for information on that unless you have some info. If I do modify this car when the time comes, I would like to maintain the driveability where is now. If I swap engines and such, will all the dash lights, gauges,etc still work the same? What kind of life can I expect from my 1.7? I have run mobil 1 since I bought it, andit has run like a top since I've had it. Also, is there a thread on here for maintenance intervals for fluids, belts, tuneup, etc? I know what the manual and honda say, but are these pretty accurate or should I do anything sooner? Thanks a lot! :) |
