2013 LX Outside temp indicator missing
Old Oct 26, 2013 | 07:07 PM
montekay's Avatar
Default 2013 LX Outside temp indicator missing
Does anyone else have a 2013 Civic LX with manual transmission? Mine has no outside temperature indicator. I was at the dealer today and they theorized perhaps the manual transmission version doesn't have it. We did check an Automatic LX and it's there on it but they didn't have another manual transmission to check. According to everything I can find it should have it but I just want to hear from someone with a manual shift that can confirm theirs has the outside temperature indicator.
thanks,
Monte
Old Oct 27, 2013 | 07:40 AM
montekay's Avatar
Default Update
I saw in another forum where a blank outside temperature display was caused by a broken wire to the sensor located behind the front bumper. I can see on mine that there is a wire hanging down with a connector that isn't connected to anything.
Anyone know how to get the plastic piece off either the top or bottom to access the area and plug it back in? Looks like just plastic snap in clips but I don't want to break anything. It would save a 40+ mile round trip drive to the dealer if I could just pop the cover off and plug it back in myself.
thanks,
mk
Old Oct 27, 2013 | 07:45 AM
Post pictures.
Old Oct 27, 2013 | 07:57 AM
montekay's Avatar
@ RonJ, not sure what you mean, post pictures of what?
mk
Old Oct 27, 2013 | 07:59 AM
Hanging wire and connector. And anything else you think may be relevant to the problem.
Pictures > 1000 words
Old Oct 27, 2013 | 08:25 AM
montekay's Avatar
Default Photos
In order to access the area where the wire is I need to remove either the top plastic cover shown in the attached photo or possibly the one underneath. I assume the plastic clips shown in the photo can be pried out with a screwdriver but I don't want to break anything so I just want to confirm this before attempting it.
mk
Attached Thumbnails 2013 LX Outside temp indicator missing-civic-plastic-cover.jpg   2013 LX Outside temp indicator missing-civic-sensor-wire.jpg
Old Oct 27, 2013 | 01:58 PM
montekay's Avatar
Default Confirmed
I still can't access the sensor but I pulled the wire out so I could reach it and connected a 1.9 K ohm resistor across it. The display came on reading 77 deg F and the menu option to adjust it is now available.
So problem solved. I'll probably just take it to the dealer and let them do it, the car is only a couple weeks old and the display has been off since Day 1.
mk
seanperia
53
Feb 3, 2011 05:09 AM
ek2ner_knox
Feb 1, 2006 11:33 AM
rawrob71
Jan 31, 2006 02:12 PM
Forty04
Jul 11, 2005 08:24 AM
