b16 potential
I have a 99 si with stock internals...and it burns oil. I was told its either the piston rings or teh head gasket....but i will find out tomorrow. but anyway, i need to know what you guys think i should do. im going to fix it, but while the motor is ripped apart i might as well build it. lemme know im open to all sorts of suggestions
RE: b16 potential
Yeah if you have the time I would do internals if your thinking of running high boost or just high compression. If you just want a cheap easy project you can get better adjustable cam gears and maybe a light weight pulley kit it would give you a lil more power. Just a suggestion tho but you can do a lot more.
RE: b16 potential
+1 to gotboost?
Im not quite sure about all of those mods but sounds like a good idea for mods |
RE: b16 potential
+1-gotboost, you couyld maybe get a aftermarket cam, or alot more, depending on time/money....
RE: b16 potential
well do you want to go na? or boost? lets just start there
RE: b16 potential
there could be couple of other bits that could be wrong with it also such as stem sills but if your getting it fixed you will find out mine was doing just the same
if i was you deffo get it ported and polished lightened and balenced lighten the flywheel but it all depends on the money you wanna spend |
