burn!
burn!
i just recently bought my electron blue pearl 99 si .. it just started to heat up while idling. when i first got it .. the temperature was always consistently cool while idling for 5-10 minutes .. but now after a few minutes the temp starts to rise .. i replaced the coolant and it still heats up .. can anyone help me out ..?? .. thanks
RE: burn!
first step is check for coolant leaks. second is replace the themostat. if it still overheats check to see if it overheats when the ac is on. check to see if you fan is running. if you fan doesn't run at all most likely that is your problem. if your fan works when ac is on but when you have it off and it is running hot and the fan doesn't come on something is wrong with your fan circuit. too many variables. if you would like help figuring it out contack me somehow.
RE: burn!
I just bought an '01 Si and I have the same trouble. If I take it through Timmy's drive through all of a sudden the temperature starts going really high and I have to turn the heat on and then it doesn't cool down again for hours. It doesn't overheat, the temperature just gets really high.
If I just drive, and don't drive slowly, stop-and-go, or idle, then it's fine.
I replaced the rad, coolant fan, and thermostat but still have the same problem. My mechanic is mystefied.
