Buy which jack for 1992 civic?
Will a 20 inch high jack lift a 1992 civic's recommended front or rear jacking point high enough to put 11 inch jack stands under the car? I want to use only the manual's recommended jacking points.
Rapid Pump® 2.5 Ton Heavy Duty Floor Jack, $80 lift range:3-20 inches Rapid Pump® 2 Ton Low Profile Heavy Duty Floor Jack $110 lift range:2.5 - 23.75 inches Rapid Pump® 3 Ton Heavy Duty Floor Jack, $80 lift range:5-18 inches Rapid Pump® 4 Ton Heavy Duty Floor Jack $110 lift range:4-20.5 inches Rapid Pump® 1.5 Ton Compact Aluminum Racing Jack $70 lift range:3.25-14.75 inches Rapid Pump® 1.5 Ton Lightweight Aluminum Racing Jack $140 lift range:3.5-17.75 inches Floor Jacks - Save on Automotive Floor Jacks at Harbor Freight Which should I get? People say heavier is better. I don't care if it's heavy. Any other considerations? Will a higher one let you do more different kinds of repairs? |
