e-brake light
i had a little fender bender, and now i see that the e-brake light turns on once in a while while driving, and yes i checked to see that it was all the way down. Is there a sensor that might have gotten loose or something? the handle still feels firm.
RE: e-brake light
That light also indicates other problems with the brake system. For example you may be almost out of brake fluid (due to a leak) so check the level in the reservoir before driving again.
RE: e-brake light
[sm=bananallama.gif][sm=pcwhack.gif]
ORIGINAL: mk378 That light also indicates other problems with the brake system. For example you may be almost out of brake fluid (due to a leak) so check the level in the reservoir before driving again. |
RE: e-brake light
+1. he's right. Use caution until you figure it out. Speak with a dealer or service center about it, maybe they can tell you what it usualy means.
RE: e-brake light
damn sounds serious, ok i hope its just low on fluid. because the crash wasnt that big.
