Engine Codes
i have noticed that there is not a post with engine codes, so courtacy of Sha_Zapple and General_Duce at my local community car forum we now have engine codes.
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp ZC JDM equivalent of D16A1 130ps D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp K20A3 2.0L DOHC i-VTEC '02+ RSX /'02+ Civic Si 160hp K20A2 2.0L DOHC i-VTEC 02+ RSX Type S 02+ Civic TypeR 200hp K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp F22A1: 1990-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 125 hp (93 kW) @ 5200 rpm, 137 lbf·ft (186 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm. F22A4: 1990-1991 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5200 rpm, 142 lbf·ft (193 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm. F22A6: 1990-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 140 hp (104 kW) @ 5600 rpm, 142 lbf·ft (193 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm. All listed above are Single Overhead Camshaft [NON-VTEC] controlling intake and exhaust, for the most part having interchangeable parts F22B1 1994- VTEC Accord, 2.2 liter (2156 cm³), MPFI fuel system, 145 hp (108 kW) @ 5500 rpm, 147 lbf·ft (199 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm. F22B2 1994- Non-VTEC Lx, Dx Accord, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5300 rpm, 139 lbf·ft (188 N·m) @ 4200 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm. It was suggested that F22B2 non-VTEC's were superior builds for turbos due to the fact that they had more low end torque curves and were easier to maintain and set up with valve adjustments required less frequently F23A5 2.3L USDM SOHC 98+ Accord DX 135hp F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL 150hp F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiR S Spec 220ps H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp *JDM: Japanese domestic market (available in Japan) *USDM: US domestic market (available in US) *ULEV: Ultra Low Emissions Vehicle Accord 5G Japan '94-'97 H22 2157 10.6:1 190hp@6800/152ft/lbs@5500 4G Japan '90-'93 F20A 1997 9.5:1 150hp@6100/137ft/lbs@5000 Civic 6G Japan '97-'00 B16B 1595 10.8:1 184hp@8200/118ft/lbs@7500 6G Japan '96-'00 B16A 1595 10.4:1 168hp@7800/118ft/lbs@4500 6G Europe '96-'00 B16A 1595 10.4:1 168hp@7800/118ft/lbs@4500 5G Japan '92-'95 B16A 1595 10.4:1 168hp@7800/118ftlbs@7300 4G Europe '89-'92 B16A1 1595 10.2:1 158hp@7600/111ft/lbs@7000 4G Japan '88-'91 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700 4G Japan '89-'92 B16A 1595 10.2:1 158hp@7600/112ft/lbs@7000 4G Japan '90-'91 B16A1 1595 10.4:1 160hp@7600/111ft/lbs@7000 3G Japan '86-'87 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700 Crx/Delsol 5G Europe '94-'97 B16A3 1595 10.2:1 158hp@7600/112ft/lbs@7000 5G Japan '92-'96 B16A 1595 10.4:1 168hp@7800 4G Europe '89-'92 B16A1 1595 10.2:1 158hp@7600/111ft/lbs@7000 4G Japan '90-'91 B16A1 1595 10.4:1 160hp@7600/111ft/lbs@7000 4G Japan '89-'92 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700 4G Japan '88-'91 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700 4G Japan '89-'92 B16A 1595 10.2:1 158hp@7600/112ft/lbs@7000 4G Japan '89-'92 B16A 1595 10.2:1 158hp@7600/112ft/lbs@7000 3G Japan '85-'87 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700 Integra 3G Japan '95-'97 B18C 1797 10.6:1 178hp@7600/129ft/lbs@6200 3G Japan '95-'00 B18C 1797 11.0:1 197hp@8000/130ft/lbs@7500 2G Japan '90-'93 ZC 1590 9.0:1 119hp@6300/105ft/lbs@5500 2G Japan '90-'91 B16A 1595 10.4:1 158hp@7600/112ft/lbs@7000 1G Japan '86-'89 ZC 1590 9.6:1 129hp@6800/106ft/lbs@5700 Prelude 5G Japan '97+ H22A 2157 10.6:1 200hp@6800/161ft/lbs@5500 4G Japan '92-'96 F22 2156 160hp@5800/156ft/lbs@5000 4G Japan '92-'96 H22 2157 10.6:1 200hp@6800/161ft/lbs@5500 |
RE: Engine Codes
you posted a d15b as a non-vtec, when it actually is vtec in JDM form. the non vtec is a d15b2 88-91 and a d15b7 92-95. but other than that nice list
RE: Engine Codes
lol well like i said it was something that was on another forum, so i cannot take any credit for it there is 2 variation of it, i think bioth have imperfrections but with that many engines to type out i can't blame them
Here is the link to the page http://www.nbautotunerz.com/phpBB2/viewtopic.php?t=1789 |
RE: Engine Codes
Here's another one.
http://www.hondaswap.com/forums/inde...howtopic=29825 Tranny specs too. http://www.hondaswap.com/forums/inde...howtopic=29829 |
RE: Engine Codes
ORIGINAL: ef4life you posted a d15b as a non-vtec, when it actually is vtec in JDM form. the non vtec is a d15b2 88-91 and a d15b7 92-95. but other than that nice list |
