engine stats
does anyone know a good site for engine stats like hp, torque, basicly anyhting like that?
RE: engine stats
name the engine and I will name the stats
RE: engine stats
k20a3 do you know the rpm the vtec should kick in at?
RE: engine stats
5500rpm I think
RE: engine stats
ok thx because i was trying to get a light to kick in when my vtec kicked in but it kept cvomming on at like 2250 and im like this cant be right so i have to go find the right pin in the damn ecu now to fix it....you dont by chance know which it is do you? i have an OBD2
RE: engine stats
give me a day or 2 and I can more than likely find it for you. I have not messed around with the 7th gens so I dont know for sure. Why not run it off your vtec selinoid?
RE: engine stats
because then i haveto poke throught the fire wall and im not too keen on that i could slip a little and mess up a wire and then 800 bux for a new harness
RE: engine stats
K20A3 2.0 16V DOHC i-VTEC PGM-FI 1998 160hp@6600rpm 132tq@5000rpm '01-'02 RSX (USA)
'02 Civic Si (USA). so your redline if probably a little higher then the 6600 mark, i would say that the Vtec should kick in closer to the 5000rpm mark cause that has the highest tq power... but like marty i am not 100% on the 7th gens |
