fastest engine you can put in 96-00 civics?
i want more horsepower, and i was curious what is the biggest and fastest engine you can put in a 1998 honda civic?
Biggest I would imagine is the 3.2L V6. Probably bigger with more modifications.
K20/K24 would be the next "biggest/fastest" I think H22 B18c1 B16 That is my order of motors. The higher you are on the list, the more expensive it will be. |
I saw on ebay a K20 engine with a 6 speed manual trans, is it possible to put that in?
depends on your budget and patience. I saw a youtube video of a civic with a chevy small block in it.
Originally Posted by hondacivicenthusiast
(Post 762859)
I'd say a K-series will be the biggest/fastest you'll be able to swap in without a lot of work. It's not as easy as a B-series swap (pretty much a bolt-in if you have all the right parts), but it wouldn't be anything like a J-swap.
If it helps, the price of K-swaps has come down considerably in the last few years. You'll still need swap-specific mounts and axles though. |
Originally Posted by cvcrcr99
(Post 762851)
K20/K24 would be the next "biggest/fastest" I think H22 B18c1 B16 That is my order of motors. The higher you are on the list, the more expensive it will be. If you're going H2B, then yes... its probably more expensive than just a straight B18c but you also get another 30 lbs of torque and 10-20 hp depending on the engines... (b18c is 170 hp max while H22 is 170 at the lowest) |
When you say its not as easy as a B swap, do you mean that the original mounts from the dy16 fit on the B series motor?
No they don't fir to a B, still need mounts. H is geometrically bigger and just leaves you less space to work with plus whatever else.
O ok.. yeah I see. Thank you
| All times are GMT -8. The time now is 12:39 AM. |
