help with auto to man swap
I hope this is the rite place to post this if not very sorry
just got a 94 civic dx auto
I have a 98 civic sedan 5spd
i wanna take the motor an tranny out of the 98 an drop it in the 94
i bought the front tranny mount that bolts to the front of the trans near the grill and all the hard lines pedals and linkage an stuff i have a hondata s300 p28 ecu my issue is that i need to know other then the top tranny tail mount is there any other mount needing to be changed or welded?
i just ordered my haspro mount an need to make sure nothing else needs to be done in order for my swap to go smooth
thank you
thank you
the 98 has different axles then the 94
so you need axles...and rotors also
and you need the starter from the 98
i thought u said the donor car was a 92 or something..
the 98 is a different generation then the 94
Sorry I wasn't very clear. I drive the 98 civic sedan 5spd an bought a 94 civic coupe auto. Both cars are in excellent condition an drivable I wanted a 2door for the longest only issue is my 2 door is auto I hate autos so I started turning it into a 5spd I changed the front tail mount an ordered the conversion mount ran my clutch line pedals an linkage I bought the s300 p28 ecu wired the reverse lights switch an neutral ss. I haven't put my d16y8 an tranny in it yet I wanted to make sure there is nothing else needing to be do to any other mounts
I'm using the starter from my 98
the cv's from the 94
There is a thread on the site that is very good but it wasn't finished
the mount on the subframe that holds the tranny do I need to do anything to it or will that be ok as is the 98 is not a donor car I ha e a d16y7 an trans that I'm gunna drop in it
Thanks
Thanks
jayde008
32
Nov 29, 2009 12:37 PM
EG_Duck
Dec 22, 2007 06:38 PM
