How difficult is it to replace a timing belt by yourself?
I will soon be purchasing a used 02 Civic with about 117k miles. I'm pretty sure the timing belt has not been replaced. How much does a timing belt cost, and just how difficult is it to open up the engine and replace it myself? How many hours of work can I expect it to take?
first off how much mechanical experience do you have?
and do you have acess to a high powered impact wrench?
and when you figure the cost(idk how much) remember to factor in the water pump and timing belt tensioner too
The timing belt is relatively cheap -- ~$30. The difficult part of the job is removal of the crank pulley bolt. This requires a strong impact wrench or a special hex tool in combination with a couple of big breaker bars and a length of galvanized pipe. You also must read up on the procedure to learn how to set the mechanical timing correctly.
RickCoMatic
Jan 5, 2009 08:17 PM
JimMayor007
Sep 26, 2007 05:28 AM
jjgarcia
Aug 22, 2004 07:39 PM
