How to: Frt bumper removal-Air bag
Old May 28, 2007 | 03:21 AM
tlkolrod's Avatar
Default How to: Frt bumper removal-Air bag
My car is a 96 civic EX. Can some one explain how to remove the complete front bumper(not just cover)? Will air bag sensor be a problem. How do you dis -arm he air bag? It looks like 4 bolts on each bumper support but the air bag problem worried me so I thought I will ask first. Thanks Toby
Old May 29, 2007 | 03:56 AM
Default RE: How to: Frt bumper removal-Air bag
as long as the car is turned off the airbag will not deploy. We took aryiman's entire setup off to mount his FMIC and never had an issue with the air bag
Old May 29, 2007 | 11:39 AM
mlobitz's Avatar
Member
.....although it can't hurt to at least disconnect the battery first........
Old May 29, 2007 | 01:50 PM
Solid_Snake's Avatar
Taking the front bumper off will not affect the SRS Airbag system. I have done it 10+ times and nothing has ever happened.
[align=left] [/align]
Old May 29, 2007 | 01:55 PM
for your information the impact/deacceleration sensor is in the SRS Airbag main module behind the dashboard.
Old May 29, 2007 | 03:42 PM
mlobitz's Avatar
Member
ORIGINAL: Solid_Snake
[align=left][/align]
What could you have possibly needed to take your entire bumper off (brackets and everything) that many times for??
Old May 29, 2007 | 04:03 PM
i had to replace the winshield washer pump, then a hose was broken, then to remove the headlights to paint them, to replace the plastic cover under the car, to install my HIDs, etc.
Old May 29, 2007 | 08:13 PM
cyberx32's Avatar
It wont be a problem, but there are more screws than just those four on top. Check on this site to see how many screws there are, its on the do it yourself section.
Old May 30, 2007 | 03:21 AM
ORIGINAL: cyberx32
Guys, he's talking about the bumper support, not the bumper cover.
But, like I said, no sensors no wires just some awkward to reach bolts.
Old Jun 1, 2007 | 07:50 AM
Live4Boost's Avatar
bumper support only has 4 12mm bolts attaching it. bumper cover has 10 10mm bolts all around to hold it on. i really cant figure out just whatyou are asking could you be alittle simpler please. to be honest after you take the cover off there really isnt much under there but a reenforcement.
EACivic
Aug 12, 2008 05:55 AM
tlkolrod
Jun 13, 2007 08:32 PM
freebass
Dec 4, 2006 01:42 PM
honda97
Jan 9, 2006 04:20 PM
lowmitsu
12
Feb 4, 2005 07:17 PM
