one dim headlight 2003 civic
Hi all, My right side head light is much dimmer than the other one, which is working fine.
I have changed the bulb, checked fuses and made sure the bulb connection is ok.
I am pretty sure it is a bad ground.
Anybody know where the ground for that is attached. Tracing it looks to be a pain.
Would appreciate any help. I Don't want to give the cops a reason to pull be over at night lol.
If you're not sure where the ground is, why not just put a quick splice into the existing wire and then attach the other end to clean connection in the engine compartment nearby. Crimp a ring end on the wire and run a nut and bolt through it.
Duane
Duane
RoundEyeRacing1904
01-02-2006 07:49 AM
