Just Seafoamed My Gas Tank
Wut type of increases should i see or differences in driving. Ive done through the hose already and just need to do the crankcase soon , when its time for an oil change (even though i think im over)
RE: Just Seafoamed My Gas Tank
Uhm. Havent you already seafoamed your car before? You will notice better idling but other than that nothing too ovbious. Didn't you put some in the gas, crank, and vac the last time you did it? Thats what your supposed to do.
did you use a whole can for the tank? i think you were supposed to only use 1/3, from reading the DIY. On my friend's car, idle was a lot smoother and accleration was also.
No i did the vac before and didnt have the right funnel to get it in the tank so i just got one and did that and only used about 1/3. I did the vac line before and worked fine. I didnt do the case at all yet.
well besides some beter idling ya realy shouldnt se emuch difference....
most the time the first time you do it is when it shows the most improvement... and after that ive never realy noticed a difference with doing it again.... tho i would sugest pulling the spark plugs and making sure they dont have any gunk on them after running the cleaner.... sometimes it can knock out some crap in the intake manifold that will get caught on the spark plug not leting them run as good.... nothing much just pull em out and blow or wipe them off |
