Keyless Entry/Power Locks
My keyless entry on my 03 Civic now only works to unlock the doors but it will not work to lock the doors. Also pressing the lock button inside the car will not lock the drivers door but only the passenger doors. Anyways else have this problem or know how to fix?
RE: Keyless Entry/Power Locks
button should lock all doors if your door is closed, otherwise just passenger doors (similar to how in older generations, you couldn't lock driver's door by pressing the switch)
i'd replace the battery in the remotes to see if that fixes it, if not, look up how to reprogram the keyless remotes to the car
I noticed the same problem with my 2000 EX. It seems that when the drivers door is open, neither the door lock button inside the car or the lock button on the remote will actually lock the door.
However, when the door is closed, everything works OK. I'm wondering if it is a lubrication issue somehow ?
Your not alone, My '94 has the same problem. Remote unlocks doors, but doesn't lock them. The remote is from the alarm system that was wired to the power locks. I thought that was the problem. Maybe no, though.The system was profesionaly installed about 10-11 years ago.I'm curious to see the responces to this topic, myself.
Güero
06-24-2008 08:58 PM
Kturner
09-25-2006 08:38 AM
