P0139
Old Oct 26, 2014 | 01:18 PM
devolic's Avatar
Default P0139
I have a 2005 1.7L DX that has over 100K miles original plugs and a lot of the other stuff hasn't been changed. I'm getting a P0139, Bank 1 Sensor 2. IIRC sensor 2 is located downstream in or near converter is that correct? What's the best way about going to fix this?
Thank-you
Old Oct 26, 2014 | 03:30 PM
Yes it is the second sensor, located at the outlet of the converter. That code may also occur because the cat is bad but usually that is a P0420.
And definitely due for new plugs and a timing belt.
Old Oct 26, 2014 | 06:14 PM
itburnswhenIP's Avatar
the dx cat is located on the exhaust manifold header in the engine bay just unplug the sensor and use a wrench or o2 sensor socket i just use a wrench.
pensacolairish
Feb 27, 2013 04:00 PM
crigby
Dec 30, 2008 08:45 AM
sparksc
Nov 11, 2006 08:32 PM
