please some one respond
My honda will not accelerate right the rpm's bounce and I have replaced a **** load of parts please some one give me some advice.
RE: please some one respond
Youve gotta be more specific, and what parts did you replace. What exactly is the car doing?
I hace changed the Air Idle Control Valve the Throttle Positioning Sensor I have changed the Throtle Body I just got done spending a $1000 on the car its a really bummer it aint running right But the Idle is fine when I give it gas it Surges the Idle will bounce. You know what I mean? Like if you were to givce it gas them let off and then give it gas and let off a bunch of times that is what it is doing when I just give it gas. Did I explain it good enough I hope so because I have to drive that car to Vegas on the 10th of march.
it could be the fuel injector. Have you put any treatment in the gas lately? It could also be the fuel filter.
a fuel filter or injector could cause that and no I havent put any fuel treatment in my car but after I got my motor back in when I started it it reved normally for the first mabey 7 minutes then when I let it Idle for a few it went back to bouncing.
Dude, please don'tpost the same problem more than once. You have3 threads open for the same question. What this does is, the next time someone doe a search they will have to wade through 3 posts instead of being able to find info in just one. Besides, it's annoying.
locked, go here: https://www.hondacivicforum.com/fb.asp?m=372004
