po5 cumputer on a d15b7 engine???
Old Jan 7, 2008 | 07:55 PM
ev2890's Avatar
Default po5 cumputer on a d15b7 engine???
Iam thinking about replacing my d15b8 engine with a d15b7 engine. Can I use a po5 cumputer on a d15b7 engine?
Old Jan 8, 2008 | 06:43 AM
my94civic's Avatar
Default RE: po5 cumputer on a d15b7 engine???
what isa PO5 computer???
Old Jan 8, 2008 | 06:48 AM
Fiirkan's Avatar
you would most likely want the ecu that came with that motor (P08) i'm not even sure what motor the P05 is for. but i have that motor right now, and it's mated with a P08 and those should be pretty cheep
Old Jan 8, 2008 | 06:57 AM
riceburner700's Avatar
p05(d15b8) reads a 1 wire o2 sensor and a p06(d15b7) readsa 4 wire 02 sensor. It will run the b7 fine. but i would recommend down the road get a p06 ecu, b7 engine bay harness and a b7 02 sensor and everything will plug right in
Old Jan 8, 2008 | 06:58 AM
my94civic's Avatar
haha, oh the ECU....
Old Jan 8, 2008 | 07:32 AM
Fiirkan's Avatar
ORIGINAL: riceburner700
you sure it's the P06? my car has a P08... but it is an auto so that could explain it as well
Old Jan 8, 2008 | 07:43 AM
did some researching an it looks like the p08 comes from the automatic d15b's.
http://www.hondata.com/techecuid.html
Old Jan 8, 2008 | 07:57 AM
Fiirkan's Avatar
then that would explain it then lol, good to know that i will be getting a p06 not a manual p08 lol
Old Jan 8, 2008 | 09:03 PM
ev2890's Avatar
if the only difference between a b8 ecu and a b7 ecu is the o2 sensor wires. could i just use a b8 o2 sensor on ab7 engine?
Old Jan 8, 2008 | 09:16 PM
yeah you could, i ran the b8 wire on a z6 mini-me and it ran just fine until the timing belt broke. no vtec but heeeeeeeeey[sm=smiley20.gif] lol
