projector headlights
Old Jan 6, 2009 | 06:08 PM
ashcheerit2000's Avatar
Default projector headlights
doese anyone know if stock light bulbs will fit in the ebay projector headlights on a 95 civic ex?
Old Jan 6, 2009 | 08:09 PM
i can't tell you what bulbs the particular projectors will use, but an H4 is dual filament and projectors don't use those, so no, they won't
they should come with bulbs though
they will most likely use an H1 or an H3 bulb, or a combination of both (i.e. H3 for low beam, H1 for high beam)
Old Jan 6, 2009 | 09:23 PM
it should say on the bulb it self what it is right, my low beams burned out and im using my highs for tempary in low beam spot there not bright enough to make ppl flash cause there adjusted can i take the bulb to advanced or autozone and they be able to give me replacement?
Old Jan 6, 2009 | 09:27 PM
it should say on the front of the clear headlight lense what they are, with an H_
it should also say on the bulb
yea it should say on the bulb itself, should either be H1 or H3 like trust said. if i were to get them i would get them from ebay and seal them good with silicone
Old Jan 6, 2009 | 09:54 PM
okiies iill take a look to see if u can find what they are, ii never knew your supost to seal them befor putiing them on car never had them fog in the year half ii had them.. thanks you guys for all your help
Old Jan 7, 2009 | 12:12 PM
yea, seal them right along where the plastic clear lens meets the housing
many of them have fogging problems because they are not sealed.
ashcheerit2000, you must have just gotten lucky and gotten a sealed pair of headlights. If you ever have the front bumper off for another reason I would seal them while it's off, but since you said you don't have fogging problems I wouldn't take the bumper off only to seal the headlights.
Old Jan 7, 2009 | 02:20 PM
FlipHKD720's Avatar
my projectors from ebay came with bulbs.....but if you're replacing them just go off of the bulb part #.
and yes, silicone sealant ftw.....well not really the win because mine still leak, but it helps lol
Old Jan 7, 2009 | 04:59 PM
V8DIET's Avatar
Lol there should be a sticky on aftermarket headlights and the need to seal them with silicone.
Old Jan 7, 2009 | 06:18 PM
that is a really good idea
seconded
