Quick spark plug question
Hi,
Just installed new spark plugs using the guide from here (https://www.hondacivicforum.com/m_228112/tm.htm). I noticed after I installed them that I was supposed to tighten using a torque wrench after tightening by hand. I only, however, tightened by hand. I started the car - it works great. Any potential problems by not tightening by torque wrench? |
RE: Quick spark plug question
Technically, you're supposed to tighten every bolt on the car with a torque wrench, there is a spec for every single one. Rule of thumb is, once you screw in the plug and it's getting tight, turn it about 1/4-1/2 of a turn.
Great! So it shouldn't be a problem then.:D
Thanks! PS. If you never see me post again on these forums, then you'll know not to skip the torque wrench. |
ORIGINAL: mustangphil302 Technically, you're supposed to tighten every bolt on the car with a torque wrench, there is a spec for every single one. Rule of thumb is, once you screw in the plug and it's getting tight, turn it about 1/4-1/2 of a turn. |
