rear disk conversion on 93 LX
I was browsing through the marketplace on H-T and came across someone selling "rear disk conversion" out off an 01 integera.... i txted them and they said that they think it will only work for the 2 door civics (so im guessing its a 2 door integera) but ive never seen anything saying one way or another.... So is the trailing arm different between the two?
I thought all trailing arms 88-00 were the same. Some had ABS, some didn't.
I believe Hobo is correct.
Honda Parts at HondaPartsDeals.com: Honda Accessory, Honda Car Parts, Honda Auto Parts, Honda Accord Parts Look up a coupe and a sedan, find the trailing arm part numbers and compare. If the first 5 numbers are the same, you can assume that they are the same part I think. Research what else you need before jumping into it. You need more than just the trailing arms. |
Originally Posted by cvcrcr99
(Post 754155)
also, found this... someone selling both front and back... would this be worth it?
Im fairly sure i would need the mc and booster when doing both... not sure about the prop valve though.... just looking for advice/suggestions at this point |
