rear wheel noise
Old May 1, 2008 | 06:38 PM
sicuro's Avatar
Default rear wheel noise
my civic makes noise at the rear right wheel when braking, and taking sharp left turns. it sometimes does it and sometimes doesnt.
then when it got louder, we took off the tire and cleaned the drum to see if that helps, and it did.. doesnt make any more noise when braking. but when we take sharp left turns there sometimes is still a little noise (but not as loud as before)
does anyone know whats up with it?
Old May 1, 2008 | 07:03 PM
macbeth18288's Avatar
Default RE: rear wheel noise
Well you could start with what year you are driving.
After market suspension? Wheels? Brakes?
and WHAT KIND OF NOISE???
Squeaking? Creaking? Grinding? What???
Old May 1, 2008 | 07:27 PM
civicexracer's Avatar
^ need those questions answered to get close to diagnosing the problem(s). there are many components that could be the culprit, bushings, shocks, bolts, brake componenets, etc..
Old May 2, 2008 | 07:08 AM
Probably the bearing. It should be nearly silent when you turn the hub by hand with the drum off. The rear wheels use conventional tapered-roller bearings that are cheap and easy to replace.
Old May 2, 2008 | 11:30 AM
sicuro's Avatar
ok sry heres more info
2004 Honda civic sedan with ~114k km on it. everything stock
its more like a grinding noise but not too loud but you can hear it clearly, its not a constant grind, it sounds like one part of it is messed up and as the wheel spins it keeps grinding on that part which makes the noise
also, couple months ago we took our car to canadian tire to get the all season tires changed to winter, and we got into an argument with the guy changing our wheels (long story, but it has nothing to do with the issue right now so ill go on) and then he decided to **** up our bolts and bearing with the air gun. later when we took it back to Honda they told us the rear bearing was broken and needed to be replaced. so we payed $400 and i suppose we should have a new one
^ if that helps
Old May 2, 2008 | 11:40 AM
Take it back to Honda again, as their bearing job went bad so soon they should do it again under warranty.
Old Jul 21, 2008 | 06:44 PM
jeebuss31's Avatar
test
Old Sep 11, 2013 | 06:26 AM
Jibletmaster's Avatar
Default Please help
2009 civic noise from rear wheel, been happenning for few months now but considerably worse since having it serviced two days ago. They said the brakes were fine, had bearings checked few weeks ago. Sounds like a metal on metal rubbing only heard at low speeds and coasting. Please help
Old Sep 12, 2013 | 05:01 AM
Will it make the noise if you jack up the car and spin the wheel by hand? If it does you can take the wheel off and listen closely for where it is coming from.
Old Sep 24, 2013 | 11:01 PM
hmoobvwj's Avatar
possibly bearing.. my car was the same, almost of grinding but wind noise coming from the back of my car.
