s2000 Cluster Swap Wiring Guide
Ok here it is. All EG EF EK DC2 gauge swaps.. Ugh, I just spent two hours doing this, hope it's appreciated.
I guess hook up all the power circuits to an ignition power source. Doesn't seem to have a wire for any memory circuit. AP2 Clusters have a clock, and probably totally different wiring. This is for the 2000-2003 S2k Gauge Clusters Holding down the SEL button will switch between KM/H and MPH Pressing the + and - buttons will change the brightness of the cluster. Connector A ----------------------------------------------- EG harness EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG 1 BLU/RED (Seat belt reminder) --------------------------- BLU/WHT (B10 Seatbelt Light) 4 PNK (SRS) CONNECT TO +12V power (A10 IGNTION POWER) TO TURN OFF LIGHT (or correct wire if you have it) 6 YEL (Fuse 5) ------ONLY IN CANADA-ONLY IN CANADA-------- BLK/YEL (A10 IGNITION Power) 7 GRN/RED (Left turn signal (+)) ------------------------- GRN/BLU (A4 Left Turn) WORKS 8 GRN/YEL (Right turn signal (+))------------------------- GRN/BLU (A3 RightTurn) WORKS 9 RED/WHT (High beam (+)) -------------------------------- RED/GRN (B1 Highbeam) WORKS If positive trigger high beam Connect A10 to ground, A9 to switch. If trigger to ground, Connect A9 to Power and A10 to switch. Probably situation 1. 10 RED/BLU (High beam (-)) ------------------------------- BLK (B6 Ground) 11 BLU/BLK (Trunk indicator) ----------------------------- GRN (B9 Trunk Open) WORKS Connector B 2 RED/YEL (Fuse 45) -------------------------------------- BLK/YEL (A10 Power) OK, B2 doesn't seem to do ANYTHING. I guess hook it up, I'll look for more details tomorrow. B3 is the switch between bright and dim. I would connect it to (red/black A11 Gauge Lights) 3 RED/BLK (Circuit 11 – dash and console lights (+)) ----- +12 dims the cluster, so A11 or A12, someone test and I'll edit this. 4 YEL (Fuse 5) ------------------------------------------- BLK/YEL (A10 IGNITION Power) 5 WHT/RED (Fuse 25) -------------------------------------- BLK/YEL (A10 IGNITION Power) 6 GRN (Door Pin Input ground signal) ------------------ Door Pin Switch I can't Find 8 BLK (Ground) ------------------------------------------- BLK (B6 Ground) 9 BLK (Ground) ------------------------------------------- BLK (B6 Ground) 10 RED (Circuit 12 – dash and console lights (-)) -------- BLK (B6 Ground) Connector C 1 Wht/Blk VSS OUTPUT ------------------------------- Use to connect to regular speedo if ya want. Step down from high pulse rate to regular pulse rate. 3 BLU/WHT (Vehicle speed signal input (-)) --------------- Connect to VSS Converter 5 BLU (RPM signal input) --------------------------------- BLU (A8 Tachometer) Should Work 7 YEL/GRN (Coolant temp input) --------------------------- Connect to ECT Converter 8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (A1 Fuel Gauge) Should Work 15 BLU/YEL (Cruise control indicator (-)) ---------------- Cruise Control I can't find, Probably Red with a Blu stripe.. Maybe B3 Probably dont have cruise control WORKS Connector D 8 BLU/RED (ABS indicator input) Connect to GROUND to turn off light or correct wire if you have it. 9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (B2 Brake Light) WORKS 11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (A5 Charging Light) WORKS (both batt and brake lights come on.) 12 BLK/YEL (Fuse 6) -------------------------------------- BLK/YEL (A10 IGNITION Power) 13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (A6 Oil Pressure) WORKS 14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (B5 MIL Lamp) WORKS 16 WHT/RED (Fuse 25) ------------------------------------- BLK/YEL (A10 IGNITION Power) AND FOR AN EF EDIT 90-91 EF CLUSTER EF 90-91 EF 90-91 EF 90-91 EF 90-91 EF 90-91 EF 90-91 EF Connector A ---------------------------------------------- EF 90-91 harness 1 BLU/RED (Seat belt reminder) --------------------------- BLU/RED or YEL/RED (B5 Seatbelt Light) 4 PNK (SRS) CONNECT TO +12V power (A10 IGNTION POWER) TO TURN OFF LIGHT (or correct wire if you have it) 6 YEL (Fuse 5) ------ONLY IN CANADA-ONLY IN CANADA-------- BLK/YEL (A10 IGNITION Power) 7 GRN/RED (Left turn signal (+)) ------------------------- GRN/BLU (A1 Left Turn) 8 GRN/YEL (Right turn signal (+))------------------------- GRN/YEL (B8 RightTurn) 9 RED/WHT (High beam (+)) -------------------------------- RED/GRN (A2 Highbeam) 10 RED/BLU (High beam (-)) ------------------------------- BLK (B1 Ground) 11 BLU/BLK (Trunk indicator) ----------------------------- BLU/YEL (A6 Door Open) Connector B 2 RED/YEL (Fuse 45) -------------------------------------- BLK/YEL (A10 Ignition Power) OK, B2 doesn't seem to do ANYTHING. I guess hook it up, I'll look for more details tomorrow. B3 is the switch between bright and dim. I would connect it to (red/black A4 Gauge Lights) 3 RED/BLK ------------------------- +12 dims the cluster- RED/BLK A4 Lts On Input 4 YEL (Fuse 5) ------------------------------------------- BLK/YEL (A10 IGNITION Power) 5 WHT/RED (Fuse 25) -------------------------------------- BLK/YEL (A10 IGNITION Power) 6 GRN (Door Pin Input ground signal) ------------------ BLU-YEL (A6 Door Open) Door Pin Switch 8 BLK (Ground) ------------------------------------------- BLK (B1 Ground) 9 BLK (Ground) ------------------------------------------- BLK (B1 Ground) 10 RED (Circuit 12 – dash and console lights (-)) -------- BLK (B1 Ground) Connector C 1 Wht/Blk VSS OUTPUT ------------------------------- Use to connect to regular speedo if ya want. Step down from high pulse rate to regular pulse rate. 3 BLU/WHT (Vehicle speed signal input (-)) --------------- Connect to VSS Converter 5 BLU (RPM signal input) --------------------------------- BLU (A12 Igniter Unit) 7 YEL/GRN (Coolant temp input) --------------------------- Connect to ECT Converter 8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (B6 Fuel Gauge) 15 BLU/YEL (Cruise control indicator (-)) ---------------- Blu/Blk Other Plug Cruise Control If you have it. Connector D 8 BLU/RED (ABS indicator input) Connect to GROUND to turn off light or correct wire if you have it. 9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (A7 Brake Light) 11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (A11 Charging Light) (both batt and brake lights come on.) 12 BLK/YEL (Fuse 6) -------------------------------------- BLK/YEL (A10 IGNITION Power) 13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (A8 Oil Pressure) 14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (A9 MIL Lamp) 16 WHT/RED (Fuse 25) ------------------------------------- BLK/YEL (A10 IGNITION Power) AND FOR AN EF EDIT 88-89 EF CLUSTER EF 88-89 EF 88-89 EF 88-89 EF 88-89 EF 88-89 EF 88-89 EF Connector A ---------------------------------------------- EF 88-89 harness EF harness. I'm calling the 12 pin connector A and the 8 pin connector B 1 BLU/RED (Seat belt reminder) --------------------------- NOPE Seatbelt Light 4 PNK (SRS) CONNECT TO +12V power BLK/YEL (A9 Ignition Power) TO TURN OFF LIGHT 6 YEL NOPE 7 GRN/RED (Left turn signal (+)) ------------------------- GRN/BLU (A1 Left Turn) 8 GRN/YEL (Right turn signal (+))------------------------- GRN/YEL (B8 RightTurn) 9 RED/WHT (High beam (+)) -------------------------------- RED/BLU (B6 Highbeam) 10 RED/BLU (High beam (-)) ------------------------------- BLK (B1 Ground) 11 BLU/BLK (Trunk indicator) ----------------------------- GRN/BLK (B7 Hatch Light) Connector B 2 RED/YEL (Fuse 45) -------------------------------------- BLK/YEL (A9 Ignition Power) OK, B2 doesn't seem to do ANYTHING. I guess hook it up, I'll look for more details tomorrow. B3 is the switch between bright and dim. I would connect it to (RED/BLK A6 Dash Lights) 3 RED/BLK ------------------------- +12 dims the cluster- RED/BLK A6 Lts On Input 4 YEL (Fuse 5) ------------------------------------------- BLK/YEL (A9 Ignition Power) 5 WHT/RED (Fuse 25) -------------------------------------- BLK/YEL (A9 Ignition Power) 6 GRN (Door Pin Input ground signal) ------------------ BLU-YEL (B5 Door Open MAYBE!! TEST) Door Pin Switch 8 BLK (Ground) ------------------------------------------- BLK (B1 Ground) 9 BLK (Ground) ------------------------------------------- BLK (B1 Ground) 10 RED (Circuit 12 – dash and console lights (-)) -------- BLK (B1 Ground) Connector C 1 Wht/Blk VSS OUTPUT ------------------------------- Use to connect to regular speedo if ya want. Step down from high pulse rate to regular pulse rate. 3 BLU/WHT (Vehicle speed signal input (-)) --------------- Connect to VSS Converter 5 BLU (RPM signal input) --------------------------------- BLU (A11 Igniter Unit) 7 YEL/GRN (Coolant temp input) --------------------------- Connect to ECT Converter 8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (A3 Fuel Gauge) 15 BLU/YEL (Cruise control indicator (-)) ---------------- NOPE Connector D 8 BLU/RED (ABS indicator input) Connect to B1 GROUND to turn off light or correct wire if you have it. 9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (B4 Brake Light) 11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (A10 Charging Light) (both batt and brake lights come on.) 12 BLK/YEL (Fuse 6) -------------------------------------- BLK/YEL (A9 Ignition Power) 13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (B2 Oil Pressure) 14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (A5 MIL Lamp) 16 WHT/RED (Fuse 25) ------------------------------------- BLK/YEL (A9 Ignition Power) AND FOR AN EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK Connector A ---------------------------------------------- EK harness 1 BLU/RED (Seat belt reminder) --------------------------- RED/BLU (A6 Seatbelt Light) 4 PNK (SRS) Connect to SRS wire, I don't know it. Or +12V power to turn off light. 6 YEL (Fuse 5) ------ONLY IN CANADA-ONLY IN CANADA-------- BLK/WHT (A15 IGNITION Power) 7 GRN/RED (Left turn signal (+)) ------------------------- GRN/RED (B7 Left Turn) 8 GRN/YEL (Right turn signal (+))------------------------- GRN/YEL (A4 RightTurn) 9 RED/WHT (High beam (+)) -------------------------------- RED/GRN (B6 Highbeam) 10 RED/BLU (High beam (-)) ------------------------------- BLK (A2 Ground) 11 BLU/BLK (Trunk indicator) ----------------------------- BLU/BLK (A3 Trunk Open) Connector B 2 RED/YEL (Fuse 45) -------------------------------------- BLK/WHT (A15 IGNITION Power) OK, B2 doesn't seem to do ANYTHING. I guess hook it up, I'll look for more details tomorrow. B3 is the switch between bright and dim. I would connect it to (red/black B13 Gauge Lights) 3 RED/BLK ------------------------- +12 dims the cluster- RED/BLK B13 Lts On Input 4 YEL (Fuse 5) ------------------------------------------- BLK/WHT (A15 IGNITION Power) 5 WHT/RED (Fuse 25) -------------------------------------- BLK/WHT (A15 IGNITION Power) 6 GRN (Door Pin Input ground signal) ------------------ Door Pin Switch Find wire somewhere 8 BLK (Ground) ------------------------------------------- BLK (A2 Ground) 9 BLK (Ground) ------------------------------------------- BLK (A2 Ground) 10 RED (Circuit 12 – dash and console lights (-)) -------- BLK (A2 Ground) Connector C 1 Wht/Blk VSS OUTPUT ------------------------------- Use to connect to regular speedo if ya want. Step down from high pulse rate to regular pulse rate. 3 BLU/WHT (Vehicle speed signal input (-)) --------------- Connect to VSS Converter 5 BLU (RPM signal input) --------------------------------- BLU (B8 Igniter Unit) 7 YEL/GRN (Coolant temp input) --------------------------- Connect to ECT Converter 8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/BLK (A10 Fuel Gauge) 15 BLU/YEL (Cruise control indicator (-)) ---------------- RED/BLU (E2 Cruise Control) Connector D 8 BLU/RED (ABS indicator input) Connect to GROUND to turn off light or correct wire if you have it. 9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (A5 Brake Light) 11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (A16 Charging Light) (both batt and brake lights come on.) 12 BLK/YEL (Fuse 6) -------------------------------------- BLK/WHT (A15 IGNITION Power) 13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (B3 Oil Pressure) 14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (B5 MIL Lamp) 16 WHT/RED (Fuse 25) ------------------------------------- BLK/WHT (A15 IGNITION Power) AND FOR A DC2 94-97 Integra DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97 Connector A ---------------------------------------------- DC2 94-97 harness 1 BLU/RED (Seat belt reminder) --------------------------- RED/BLU (C1 Seatbelt Light) 4 PNK (SRS) Connect to SRS wire, I don't know it. Or +12V power to turn off light. 6 YEL (Fuse 5) ------ONLY IN CANADA-ONLY IN CANADA-------- BLK/YEL (C11 IGNITION Power) 7 GRN/RED (Left turn signal (+)) ------------------------- GRN/BLU (C13 Left Turn) 8 GRN/YEL (Right turn signal (+))------------------------- GRN/YEL (C14 RightTurn) 9 RED/WHT (High beam (+)) -------------------------------- RED/GRN (C15 Highbeam) 10 RED/BLU (High beam (-)) ------------------------------- BLK (D6 Ground) 11 BLU/BLK (Trunk indicator) ----------------------------- GRN (C7 Trunk Open) Connector B 2 RED/YEL (Fuse 45) -------------------------------------- BLK/YEL (C11 IGNITION Power) OK, B2 doesn't seem to do ANYTHING. I guess hook it up, I'll look for more details tomorrow. B3 is the switch between bright and dim. I would connect it to (red/black C10 Gauge Lights) 3 RED/BLK ------------------------- +12 dims the cluster- RED/BLK (C10 Lts On Input) 4 YEL (Fuse 5) ------------------------------------------- BLK/YEL (C11 IGNITION Power) 5 WHT/RED (Fuse 25) -------------------------------------- BLK/YEL (C11 IGNITION Power) 6 GRN (Door Pin Input ground signal) ------------------ Lt. GRN/RED (C2 Door Ajar) 8 BLK (Ground) ------------------------------------------- BLK (D6 Ground) 9 BLK (Ground) ------------------------------------------- BLK (D6 Ground) 10 RED (Circuit 12 – dash and console lights (-)) -------- BLK (D6 Ground) Connector C 1 Wht/Blk VSS OUTPUT ------------------------------- Use to connect to regular speedo if ya want. Step down from high pulse rate to regular pulse rate. 3 BLU/WHT (Vehicle speed signal input (-)) --------------- Connect to VSS Converter 5 BLU (RPM signal input) --------------------------------- BLU (D13 Igniter Unit) 7 YEL/GRN (Coolant temp input) --------------------------- Connect to ECT Converter 8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (C3 Fuel Gauge) 15 BLU/YEL (Cruise control indicator (-)) ---------------- RED/BLU (D5 Cruise Control) Connector D 8 BLU/RED (ABS indicator input) -------------------------- BLU/RED (C8 Abs Light) 9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (C16 Brake Light) 11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (D9 Charging Light) (both batt and brake lights come on.) 12 BLK/YEL (Fuse 6) -------------------------------------- BLK/YEL (C11 IGNITION Power) 13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (D11 Oil Pressure) 14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (D12 MIL Lamp) 16 WHT/RED (Fuse 25) ------------------------------------- BLK/YEL (C11 IGNITION Power) AND FOR A DC2 98-01 Integra DC2 98-01 DC2 98-01 DC2 98-01 DC2 98-01 DC2 98-01 DC2 98-01 DC2 98-01 Connector A ---------------------------------------------- DC2 98-01 harness 1 BLU/RED (Seat belt reminder) --------------------------- RED/BLU (C8 Seatbelt Light) 4 PNK (SRS) Connect to SRS wire, I don't know it. Or +12V power to turn off light. 6 YEL (Fuse 5) ------ONLY IN CANADA-ONLY IN CANADA-------- BLK/YEL (C11 IGNITION Power) 7 GRN/RED (Left turn signal (+)) ------------------------- GRN/BLU (C13 Left Turn) 8 GRN/YEL (Right turn signal (+))------------------------- GRN/YEL (C14 RightTurn) 9 RED/WHT (High beam (+)) -------------------------------- RED/GRN (C15 Highbeam) 10 RED/BLU (High beam (-)) ------------------------------- BLK (D6 Ground) 11 BLU/BLK (Trunk indicator) ----------------------------- GRN (C7 Trunk Open) Connector B 2 RED/YEL (Fuse 45) -------------------------------------- BLK/YEL (C11 IGNITION Power) OK, B2 doesn't seem to do ANYTHING. I guess hook it up, I'll look for more details tomorrow. B3 is the switch between bright and dim. I would connect it to (red/black C10 Gauge Lights) 3 RED/BLK ------------------------- +12 dims the cluster- RED/BLK (C10 Lts On Input) 4 YEL (Fuse 5) ------------------------------------------- BLK/YEL (C11 IGNITION Power) 5 WHT/RED (Fuse 25) -------------------------------------- BLK/YEL (C11 IGNITION Power) 6 GRN (Door Pin Input ground signal) ------------------ Lt. GRN/RED (C2 Door Ajar) 8 BLK (Ground) ------------------------------------------- BLK (D6 Ground) 9 BLK (Ground) ------------------------------------------- BLK (D6 Ground) 10 RED (Circuit 12 – dash and console lights (-)) -------- BLK (D6 Ground) Connector C 1 Wht/Blk VSS OUTPUT ------------------------------- Use to connect to regular speedo if ya want. Step down from high pulse rate to regular pulse rate. 3 BLU/WHT (Vehicle speed signal input (-)) --------------- Connect to VSS Converter 5 BLU (RPM signal input) --------------------------------- BLU (D13 Igniter Unit) 7 YEL/GRN (Coolant temp input) --------------------------- Connect to ECT Converter 8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (C1 Fuel Gauge) 15 BLU/YEL (Cruise control indicator (-)) ---------------- RED/BLU (D5 Cruise Control) Connector D 8 BLU/RED (ABS indicator input) ---- ABS light or connect to ground BLK D6 to turn off light 9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (C16 Brake Light) 11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (D9 Charging Light) (both batt and brake lights come on.) 12 BLK/YEL (Fuse 6) -------------------------------------- BLK/YEL (C11 IGNITION Power) 13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (D11 Oil Pressure) 14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (D12 MIL Lamp) 16 WHT/RED (Fuse 25) ------------------------------------- BLK/YEL (C11 IGNITION Power) Courtesy of bigcalidave for writing this http://www.honda-tech.com/showthread.php?t=1570344 |
Originally Posted by supersize
(Post 694275)
I guess hook up all the power circuits to an ignition power source. You guess hook up all the power circuits to an ignition power source? Do you know if this even works? I once had an AP1 cluster in my hands, ready to put in the car. Tried to wire it using basic information... nothing. It's ALOT harder than it looks... especially to get everything 100% functional such as the speedometer and the ECT gauge. |
^lol, I think he copy/pasted what you quoted too
I think rywire.com makes a plug n' play harness (you have to buy VSS signal converter and other converters still though) |
I think the speedometer signal converter was called 'speed healer' but I've heard that it's no longer made...
@cvcrcr99: copy and paste lol
@trust: yes there is some kind of harness thing for it, alot of people are doing it on HT now @danomatic: all you need to do to the vss is convert it from analog to digital, it will take the analog data, convert it to digital and display it |
(Post 694439)
@trust: yes there is some kind of harness thing for it, alot of people are doing it on HT now @danomatic: all you need to do to the vss is convert it from analog to digital, it will take the analog data, convert it to digital and display it Anyways, Danomatic.... this is what you are referring to I believe. http://www.healtech-electronics.com/ -Click on "Speedo-healer" on the left side after the page loads. Supersize, read my post in the DIY section overhaul thread. I'll gladly quote it and post it here if you want. I didn't post it here originally since I understand you are trying to help out. |
this isnt a DIY, thats why it dosent say DIY at the top, it just a guide to tell you what wires go where. Wasnt the idea of the diy overhaul suppost to be copy and paste useful info to bring it to hcf? but whatever, delete all of my DIY's since i dont know anything..
You're still missing the part about letting me know about all these DIYs you're supposedly posting so I can put them on the list.
(Post 694482)
DIY, Install Guide, Guide, How To:, are all the same things. I would never try to come off as a d!ck, especially to members who are active and contribute to help the forum. I appreciate your effort, but try and understand where I am coming from. People see the "guide", feel they can do it, start, realize half way through that the guide isn't complete, and get pissed when no one can help them and leave the site. Sorry if you feel the way you do. |
nah i completely understand what your saying, the reason i was posting them was because we were suppost to be adding all these new ones to bring people in, and if they have questions, why would they pm me when they can post it in the topic itself?
questions to me = just me being able to answer questions on the topic = everyone being able to answer ya know what i mean? i just dont understand how me posting diy's is going to piss someone off. And how did you defend me on the diy's? i was told my greddy that "my way to help" would be to copy and paste diy's and give credit to the OP's and give a link.. what, people dont want me posting diy's because im suppost to be the post whore who dont care about the site and just start fights with people? i mean if you dont want me to post technical diy's, i wont, i just diddnt know where it was comming from because on one hand, im being told i can help out the site by posting stuff, and on the other hand, im seeing that diy's shouldnt be posted by people who dont know what their doin.. its whatever tho, next time im fukkin around in photoshop, ill make some more diy's |
