scion tc vs my civic
Hmm... I assume you've soaked the nuts in PB Blaster or something like it already.
You said you have a deep well socket. I'd say try putting about a 4" extension on the deep well, so the ratchet can clear the valve cover. Then, get a pipe or something that fits over the handle on the ratchet (or breaker bar, whatever you're using) to get a little more leverage & torque. Then, crank on it. Also, don't break the studs lol
Also, if you're using a 3/8 drive, have you tried moving up to 1/2 drive if you have the tools? And are you using a 6pt socket or a 12pt? A 12pt socket has a better chance of rounding the nuts off.
whats even crazier reaper is on the same dyno tests the actual crap wires i.e. Duralast actually outperformed heavier gauged wires such as MSD and NGK... why I dont know... I would never waste my money, the last chart I looked at was done with 145XXX miles on the OEM wires too (the best result)... not too shabby
^ I'd assume it has to do with the resistance of the wire. The larger gauge wire would have less resistance, but I don't really know how that would have a bad effect on performance.
And enigma, glad to hear the pipe trick worked... it's saved my a** more than once
It's all about quality, material, and finish. The aftermarket wires that are ridiculously large are very poor quality. Plus the factory tune is programmed to work more efficiently with the oem size and quality wires. In the world of electronics, the circuit is only as good as it's weakest link (like a 0 gauge ground wire connected half-***, just barely touching any metal. even though the ground cable is huge, the ground itself sucks.
ran into another problem... iv been at this for an hour. i cant get the screw back in its hole!!! i use a flat head driver in one and and the screw in the other and push at same time to get the scew in hole and i just cant do it. i cant get the thing push to the side and get the screw in at same time... whats the deal? things real tuff to move too...
your looking at the screw thats on the side of the right shock tower.
ok so i found out that using a spring puller works, but i need some one to slide the bolt in as a pull the hole over. so reaper come over and help me . lol, gess ill just wait for mom. she help me install the hood, thats what mom's are for.
This was a fial too, cant get the bolt in the hole with the puller in there....i dont even know what this screw gos to..bull****
