spark plug
ok i got this spark plug wire 10 mm at ebay for my
civic is it supoust to b a lil lose on top of the spark plugs ?? and my check light went on is this supoust to hapen?? went to pepboyz they said it maybe a bad cilinder or the spark plug but the cilinder was fine is that normal juss because its aftermarket? its an ex vtec 98 thx yall...... |
go here HOW TO CHECK YOUR CHECK ENGINE LIGHT
tell us what the code is then we can tell you more from that |
ok thx ill prob do that 2morrow then ill post the results
I would just replace the cheap aftermarket wires with ngk's or any other factory equivalent and see if the wires are the problem. It could be a misfire due to crapping wiring.
i replaced my wires with MSD 8.5, no check engine light and i don't think it should be loose. its probably bad ebay spark plug wires that is giving you the light. if it is the ebay wires giving you the engine light then you should replace them with OEM equivalent or better wires
Get rid of those crap wires.
Yeah put stock wires on, they are all you need.
| All times are GMT -8. The time now is 05:24 AM. |
