vtec help!!
My vtec kicks in at 6k -6500 is this normal shouldn't it kick in at 5500 I'm a rookie at this could use a lil help ???
What year/trim/motor/ecu do you have?
It's a 99 civic ex with a b16 with gsr head and gsr trans was told when I bought it has a p2p from an si
Well, you apparently need tuning. My suggestion is to convert to a P30, or P28 ecu, chip it, and get it tuned. The tuner can play with the vtec set-up.
Ok thanks
I put in a new thermo and its working great now just an idea I had it worked
Good luck with everything. I can't imagine how a tstat would delay the vtec engagement point since they are entirely different systems within the car. The only way a Tstat could possibly affect the engagement to my knowledge is if the Tstat is stuck open, not allowing the car to warm up.
I seriously recommend you getting the car tuned though. |
I thought that until it was warmed up, into closed loop, and no DTCs, VTEC would be disabled. But that is with the stock software. You shouldn't be taking a cold engine up to 5 grand anyway.
I was told it wasn't getting warm enough I also got it tuned yesterday thanks
Ok well the motor not getting up to temp would disable vtec. /story.
| All times are GMT -8. The time now is 01:12 AM. |
