windshield washer fluid jet problem
Few days ago my washer fluid light came on so I put a bottle of fluid in. A day or so later when I go to use it, the fluid hits about an inch above the wipers. I haven't changed anything besides adding the fluid, and it seems a lot of fluid is still coming out. Its also been around 0 degrees C lately so its not ice build up. Any tips to check?
Its an 03 civic LX and the fluid jets are pointed all the way up to the top. |
RE: windshield washer fluid jet problem
Maybe the pump went bad.
Darksun:
Use a pin to aim the jets, somtimes to get mis aligned and shoot all over the place. Take the pin and stick it in the hole, thenaim them accordingly. Will take a few practice shots to get it just right. |
you could take the fitting off the pump and compress air up the line to try and blow the line out. might have something stuck in it
