got some questions about parts
hey what are the best upgrades for the money i have a AEM short ram intake doing exhaust right now. is intake manifold worth buying. or like fuel injectors. dont now im going to research it right now but i still wont some other advice thanks very much.
guessing you have a 92 civic dx with a d15 motor, i say buy a d16z6 head its a vtec head and comes from any 92-95 civic ex or si. and you will need the distributor and ecu, and some extra wire, google mini me swap if you have any questions or ask us, this will give you a great gain in horsepower and you will have vtec yo!
your bother, is wrong and you can tell him that
if you wanna spend the money for a turbo kit, and also having it tuned you will be happy
just get a good full turbo kit, not an ebay kit
if you done have a p28 ecu then get one and have it chipped and tuned
and make sure you get arp headstuds and also upgrade your fuel injectors
you just need to do some serious research about it, and if you have any questions about it, just ask.
a few questions you will need to answer so we can help you determine what all you need to do
how much hp are you wanting?
how much are you wanting to spend?
who will be doing this work?
do a compression test on your motor to find out what shape its in.
as long as you have a proper tune and everything is done right your motor will be fine.
i've been feeling alot better in the past 2 days, i actually worked some yesterday and today, and i got a few jobs to do tmw, im just taking it easy and just doing lite jobs until i feel ok enough to do serious work.
fuel injectors are not a modification you just spontaneously do... your engine has to require more fuel before you can give it more fuel, otherwise you will just run rich. There is a thing called an air/fuel ratio and it is important to maintain the correct ratio. Throw high flow injectors on there without giving the engine more air per amount of time (i.e. a turbo) and you run hella rich. You don't gain power just from giving the engine more fuel.
thus the reason i said serious research and ask questions, there is also alot more but i didnt want to sit here and type all night
