1989 civic header!!!!!!!!!!
RE: 1989 civic header!!!!!!!!!!
If you have the money, a bisimoto is the best you can buy. Unfortunately, the price tag on a bisimoto header is unbelievable. if you don't have the funds for a bisimoto, try DC Sports, Hedmen Hedders, or Megan Racing. All three of the lower-grade headers give about the same power gains; the DC, however, carries a price tag ofdoubleits counterparts
Well, if you live in a place like Cali, where the emissions testing and everything is really strict, you can't really get the Megan Racing header, since it's not 50-state emissions legal. That leaves you with the DC and Hedmen;honestly, they both offer about the same gains. So, I'd say go with the Hedmen Hedders Chikara header. It's $145 at http://www.summitracing.com/; mine was around $160 with shipping and everything. You might need this http://passwordjdm.com/PasswordJDM-O...P1767C320.aspx... it definitely makes things easier.
I'm not that familiar with older civics features (or maybe it's just the concussion that I got today that's keeping me from remembering), but do the 4th gens have catalytic converters?
If you have the money, bisimoto headers are absolutely the best you can buy for a civic. Unfortunately, they're $500+. If you can afford to spend that much on a header, without a doubt, go for it!!! You won't regret a bisimoto. They gain somethingaround 10hp at thewheels on a stock civic. Hey, they built the world's fastest SOHC civic; I think they know what they're doing
If you don't have $500 or more to spend on a header, go with something like Hedmen or Megan Racing. They still offer good gains (but not as good as bisimoto's 10hp), and are a lot cheaper.
http://www.hadamotorsport.com/tech/r...emc/index.htmlhere, this might help
ya that helps a lot and good info thanks.. also i just bought this it has an intake that is it also im saving up for a k20a engine what else would be something easy and affordable for some more power???
good luck saving up for a k20... those things are amazing, but expensive. Anyway, since you're getting a swap, I wouldn't sink too much money into the motor you have now, so I'd say keep things naturally aspirated.
So, the next step after a header would be a cat-back exhaust. They're usually $400+, and please don't get a cheap one off ebay; they tend to sound horrible. Also, make sure it's a cat-back. A muffler on stock tubing won't do anything, and an axle-back won't gain as much as a cat-back. If you plan on keeping your stock engine for a while before swapping and the 10-15hp or so that an i/h/e gains just isn't enough for you, the next step would probably be a new cam. A good street cam usually gains 6-8hp or so. You can get a stage II cam that will gain a bit more power, but the powerband is usually past the stock redline, so you'd need to upgrade the stock valvetrain, which means more money.
Personally, since you're planning a swap, I'd stick with just an intake/header/exhaust as far as the motor goes. If you absolutely must buy car parts, I'd say work on the suspension and everything; it's what I'm doing (I'm swapping my D16 for a B16 in a year or so, so I'm not really doing much to the stock Z6)
ok ya thats smart thing and ya i know its a lot im saving hard time for it..... and ya ok so an exhaust and i think im going to switch out the short ran for a cold air one but still go for the header.... and exhaust ill do
If you already have an aftermarket short-ram intake, I'd say keep it. At most, change the filter. The power difference between a short-ram and cold-air intake is very, very minute (like 1hp or less).
Another thing you can do to gain a little bit of power back (if you haven't already done this) is to do a general tune-up. Replace the spark plugs, wires, air filter, etc. And just as a little side note, just get stock replacement spark plugs and spark plug wires; the stock ignition system doesn't fail until over 500hp. Also, using seafoam could probably help, too... I need to remember to seafoam my engine soon.
