will this work its made for a 1.5l which mine is? i probably will need to tweak it a bit
i am not bumping i just would like an answer thanks |
what part of the intake? do you mean the intake pipe? or the intake manifold?
if your talking about a intake pipe and filter then yes, |
it will work even if its made for a crx aslong as we have the same motor the intake will fit
so long as its the same series block... d series will fit d series , b series will fit... and so forth, but the computer may not work ....... like if you were going from dpfi to mpfi.. it is not plug and play
first you need to answer my question... what ""intake are you talking about"
if you are talking about the pipe and filter it will fit ANY 88-91 civic |
dude... a d series manifold will fit a d series block etc... any head will fit the same series block, and any manifold will fit same series head... exhaust or intake.
but is it a good idea... sometimes it is. thats how come its possible to add a vtec head.. or switch from dpfi to mpfi.... but there are ecu considerations to think about |
ok....
Originally Posted by jwsimons
(Post 736541)
wrong, a b16 intake manifold will not fit a b18 and vise versa. |
