AEM intake care?
Hey, So i have an AEM intake and I was wondering if i need to change it\clean it every so often?
thanks, 98 Civic Nighthawk "Nitrous ... is like a hot chick with an STD you know u wanna tap it but your scared of the consequences!!!!" |
yes... is this a dryflow filter if so you need something like this http://www.amazon.com/AEM-21-110-Dry.../dp/B0012UO00S
K&N sells the oil and cleaner for your filter. Go to any local auto parts store they will have it. Runs about 10-12bucks for the kit...looks just like the stuff post above ^^
Thanks guys
How often should i clean it?
Hey, SFAZN we should rip it around the bay sometime.
well I clean my CAI filter every time I do a oil change b/c I don;t have a fender well cover that shields my filter from all crap on the road and the air. I use to clean mine every 2 oil changes at 6,000 miles..now I do it every 3k when i cahnge my oil
Originally Posted by boreddude564
(Post 735042)
(Post 735041)
Q: How long will a DRYFLOW filter last? A: If you clean and maintain your DRYFLOW filter, it will last for the life of your vehicle. Q: How often should I clean the DRYFLOW filter? A: Frequency of cleaning for your DRYFLOW filter will depend on the conditions in which you drive. As a rule, we recommend that you clean your filter a minimum of every 30,000 miles, inspect it during oil changes and regular service intervals, and clean it if it appears to be reaching its dust holding capacity. If you live in particularly arid, dusty climates or venture off road, we recommend cleaning the filter every 3,000-5,000 miles. Q: Will frequent cleanings affect the DRYFLOW filter's longevity? A: No. The DRYFLOW filter’s polyester synthetic media can endure repeated cleanings without significantly degrading the media’s filtration capabilities. If you clean and maintain it properly it will last for the life of your vehicle. Q: Can I use a different type of cleaning solution on my DRYFLOW filter? A: To ensure optimum performance and filtering capabilities, use AEM’s Filter Cleaning Solution (part number 21-110) or a mild multi purpose cleaner and follow our cleaning instructions. |
thanks
Originally Posted by flcb7
(Post 735015)
I clean mine at every (synthetic) oil change (about 4000-5000 miles). |
