AEM V2 ?
Old Jan 16, 2007 | 12:43 PM
blackmetal619's Avatar
Default AEM V2 ?
so i installed my V2 yesterday, and the directions were unclear so i had a question about the smaller intake tube, the one that has the filter connected to it...where does it rest?i know theres a little rubber thing that sticks out of the mount, but does the tube just sit on the rubber part? Does it screw on next to the rubber? where does it rest?
[IMG]local://upfiles/13552/65BB0CB705C94CB3B2BBC5926370FE96.jpg[/IMG]
Old Jan 16, 2007 | 01:27 PM
FlipHKD720's Avatar
Default RE: AEM V2 ?
I think you loosen up the nut on your strut and put that bracket undernaeth it then tighten it back down. idk if theres specs on the strut bolt though, so u might havta check that. You can kinda see it in this picture:
Old Jan 16, 2007 | 03:14 PM
ok thanks...so far no problems, nothing has loosened, and everything is solid, im just a little skeptical about the strut
Old Jan 16, 2007 | 03:29 PM
FlipHKD720's Avatar
i just tightened mine down with a socket (when i put my strut bar on), and i havnet had any problem. This was like a year ago too.
Old Jan 16, 2007 | 03:58 PM
so the only thing holding your intake on is where it is actually connected? and the clamps are just really tight holding the second piece on to it?
Old Jan 16, 2007 | 04:06 PM
FlipHKD720's Avatar
well if you put that little bracket under your strut bolt and tighten it down really good, it really shouldnt move that much...it should keep the filter up and out of the way
magiconthetire
Jun 28, 2008 09:11 PM
Luckycapone
Dec 25, 2007 12:01 PM
CivicN33b
Mar 7, 2007 07:40 PM
etarted
Sep 2, 2004 11:47 PM
chickenhawk044
Jul 16, 2004 08:51 AM
