after I/H/E
I've completed the big three. I will most likely swap my sri for a v2 and get a HFC a little later. But what now? Should I still continue to upgrade my air flow (bigger TB, intake manifold) stuff like that or just move on to a cam? Also how much gain could I expect from a good HFC?
a lot of people would probably say a cam but then you have to get better springs and retainers and a lot of work in labor and what not, i would say:
throttle body and a intake manifold
i had kind of the same question. i didnt know if once you start putting on throttle body, intake manifold, you would need to start adding aftermarket fuel components such as fuel rail, regulator, etc. to keep it balanced?
ORIGINAL: riceburner700
that is another good point i guess it all depends on the cam you go with... what is your goal for the car are you going forced induction or n/a, that would make a pretty good difference on what cam you would go with
sacicons
Jan 30, 2005 03:06 PM
tgamer
Jun 27, 2004 06:29 AM
Robsonline
Apr 27, 2004 11:08 PM
