Breather for CAI?
Breather for CAI?
I got this from ProjectH's post talking about simple mods for free power...
Can someone explain to me what exactly that means? What are breathers? Where can I buy one? I am waiting for my CAI from the SIMOTA guy and I am always up for getting more... any other thoughts on this breather he talks about? (I have 04 Civic LX sedan 1.7l would it make a difference?)
VALVE COVER BREATHER:
If you have a cold air intake (I hope you do at this point). Get a valve cover breather instead of using that little hose that connects the CAI to the valve cover. Put the breather on your valve cover so the raw exhaust emitted (very little) does not end up in the intake. Be sure to block off the hole you now have on your CAI instead of adding a breather here, as it would have no purpose.
RE: Breather for CAI?
a breather on any car ricurculates the engines "blow by"back into the intake system to get burned in the combustion chamber
blow by is not raw exhaust - it is actually a combination of oil vapors & air & fuel that sneeks past the piston rings on the compression stroke -so the more your piston rings wear the more blow by you get
if you dont have 1 or if its clogged up the crankcase builds up pressure -them you start blowing out seals & gaskets
so i cant see how you would gain any power by just blocking it off at the intake side
the vapors that get sucked in are minimal
but thats just my rant
ummmm.... I dont understand... So breather is good or breather is bad? You reccommend just connecting the little hose on the CAI to the engine block? I guess I dont understand WHAT it is and not so much at what it does...
ORIGINAL: AOL.COM
in a nutshell- a breather is good - i have mine hooked up to my cai
So from what I'm getting here is you PLUG the hole where your hose (on the CAI) to the engine goes, and instead use a breather where the hoes from the engine to the CAI would go. You would still have the Air Intake Temp Sensor connected right? Heres a pic let me know if I'm getting it right.
And then the open hole on the engine gets capped with the little read filter (breather) like Forty's pic above.
What is the purpose of doing this just wondering?
