cat
when i got my car it was straight piped it sounds pretty good but it is to raspy and crackely and back fires some time . if i ad a high flow cat will this stop that and i still have the factory resignator.
RE: cat
Yeah you def should get a resonator, I recommend magnaflow. Also if your getting backfiring check your spark plugs and buy the kind it says in the manual. I had platinums and was getting crazy backfiring... A high flow cat might help but it will make it even louder.
RE: cat
Your saying the Magnaflow Hi-Flow Cat will be louder than him running his straight pipe?
RE: cat
ORIGINAL: bcrichguitars Your saying the Magnaflow Hi-Flow Cat will be louder than him running his straight pipe? |
RE: cat
^ right, yeah it wont be louder than haveing no cat at all. But it will still be a little raspy unless you have a stock cat.
RE: cat
what could i use to cut exhaust piping
RE: cat
exhaust shops use a special cutting tool that i'm sure you could get somewhere. You could use a hacksaw though. It'd be easier with the exhaust off of the car.
