Cat back exhaust.
Old Dec 18, 2007 | 05:21 PM
boombringer's Avatar
Default Cat back exhaust.
Can I put a cat back exhaust on a stock car? Will it fit becouse the cat back is 2.5" ID and stock like 2".
Thanks.
Old Dec 18, 2007 | 05:33 PM
Civic Si 00's Avatar
Default RE: Cat back exhaust.
I'm assuming if you get a brand name like Magnaflow you won't have any problems at all
Old Dec 18, 2007 | 06:02 PM
KoshaK's Avatar
^ Yea. It will fit.
Old Dec 18, 2007 | 06:39 PM
ORIGINAL: Civic Si 00
How? It doesn't make any scense. Then what if I had 2.5" headers? Then would that fit also, then if both fit then there would still be a 2" id in your exhaust nullifying the headers and cat back. If you have 2.5" piping with one peice of 2" id pipe then there is no purpose of ether the headers or cat back. the 2" will restict to 2" no matter how big the other piping is. We call that a bottle neck, which is bad.
Old Dec 18, 2007 | 07:50 PM
No matter what but the cat back exhaust will connect all the way up to your catalytic converter not to the headers
What yr is it and model
Old Dec 18, 2007 | 08:05 PM
conceptualpolymer's Avatar
Correct, and most header pipes neck down a bit. Unless your engine is cranking out300 HP, there is no need to run 2.5 inch or 3-inch diameter pipes all the way back.
BTW, I just ordered a set of Magnaflows. Those and AEMs will go in during Christmas break.
Old Dec 18, 2007 | 08:07 PM
ORIGINAL: conceptualpolymer
Nice. That's bad Azz bro
Old Dec 19, 2007 | 07:17 PM
Hey, it almost looks like I'm copying your setup - Eibach springs, Magnaflows, AEM intake....
....although I made my own shift ****....
Old Dec 19, 2007 | 08:43 PM
SevenKRedline's Avatar
Member
Those of you with Magnaflow exhaust....how do they compare to the Greddy Evo 2 and SP2 systems? Ive got the Evo 2 and I LOVE it! As for performance wise, is there any difference? I guess it would all depend on the engine mods, correct? Im just curious. I paid $650 for that cat back system, so it sure as hell better be a good one!
Old Dec 20, 2007 | 09:28 AM
Then that means they're just noise makers like intakes.
