cat back question
ok when i instal the cat back in my car. (01 civic ex) will i have to worry about 02 sensors? i got a skunk2 should i have anything to precaution? besides plenty of wd40.:D
RE: cat back question
No, you won't have to worry about anything. The exhaust bolts right up, and you are ready to go. Let the WD-40 sit for about 10 minutes before you start the installation, just to give it time to penetrate the rust. Good Luck!!!
thanks alot!:D
if you exhaust is real rusty like mine was, take the time and spray it for a couple days before you attempt to install it, I had to get a couple of the nuts cut off bc they were rusted so bad.
you won't even have to touch the o2 sensors if its a catback
hehe...penetrate :D
^2610 useless posts later...:D
I had to cut a couple of my bolts too, the ones connecting the cat to the stock cat-back. That sucked. But if you use some PENETRATING stuff and/or wd-40 you'll have better luck. |
