catback system
ok i want to get a tanabe catback system with headers, first thing i am confused about is," do i have 2 get speciffic headers that are compatible with my catback" what is the down pipe for ?someone said i should get that but dont know how and for what? and the ctaback system does not include cat. converter, do i have to buy a high flow cat. converter or can i use my oem cat. converter?
RE: catback system
1. the header connects to the cat. and most are designed to work with the oem cat. so no, u dont need to worry about buying a header that connects with a catback exhaust.
2. downpipes are for turbos, since ur getting a header, u wont need a down pipe. 3. catback exhaust do not include a cat, but some(like magnaflow) come with a test pipe which replaces the cat, which is illegal in most states. 4. u do not have to but a high flow cat but u will get a tiny bit more power out of one. u can use the oem cat. |
RE: catback system
^^^You can use the OEM cat IF you can get it off of the rest of the exhaust...depending how old it is it may be rusted on there!
RE: catback system
ya...i had to use my test pipe for about a week cuz i couldnt get my stock cat off. ended up torquing the rusted a$$ bolts enough to break them off and used the new bolts.
