cold air intake question
Old May 16, 2006 | 06:10 PM
civicswaph22's Avatar
Default cold air intake question
I JUST COMPLETED AN H22 SWAO IN MY 97 CIVIC COUPE ....... I WANT TO INSTALL A CAI AND AM NOT SURE WHICH ONE WILL FIT PROPERLY ON A HYBRID SWAP
DOES ANYONE HAVE ANY SUGGESTIONS.........
Old May 16, 2006 | 07:17 PM
neon_killer's Avatar
Default RE: cold air intake question
depending on where the throttle body is and where the old one was located, should be facing torwards the passenger side shock tower, and on how much room is left over to fit it in there cause h22 are pretty big, ind whatch out for water puddles and you intake cause they tend to suck up water pretty easy and hydro lock the motor and that would suck
Old May 17, 2006 | 09:41 AM
rice_patrol's Avatar
heres one...
Honda Civic 1996-00 w/ H22A 21-5008C N/A New Release $272.50
http://www.aempower.com/product_intake_app.asp
Old May 17, 2006 | 09:48 AM
dj_ipirate's Avatar
consider a short ram
Old May 17, 2006 | 02:28 PM
Ei8's Avatar
Ei8
I agree. A short RAM might be better in your situation. AEM or INJEN make good ones...
Old May 17, 2006 | 09:42 PM
Nail I3unny's Avatar
ORIGINAL: rice_patrol
heres one...
FTW...
Old May 18, 2006 | 05:45 PM
Impreza WRX's Avatar
That's my question when I saw this torque curve!
http://www.aempower.com/pdf/dyno/24-...b%20charts.pdf
Old May 18, 2006 | 11:50 PM
fastman90's Avatar
Correct me if I'm wrong, but those gains looks slightly inflated. I'm sure that some civics might generate that much more hp and tq, but generally you won't gain quite that much unless you have already done header and exhaust, in which case an intake would do more than on a stock engine. Generally you will see max gains around 5hp and 5tq from what i have heard and read in other sources.
Old May 19, 2006 | 10:22 AM
damn that is one hell of a gain....i think thats slightly inflated.
Old May 19, 2006 | 04:08 PM
fastman90's Avatar
Yeah, you have to keep in mind when looking at companies dyno sheets that they only put the really good ones on there, if you want a more realistic look at what a cai would gain you just google something along the lines of "civic cold air intake dyno" or something and find one done by a person on their own car, on by a company on one of their cars. Even if it is slightly inflated though, the aem cai's do make better power than most other intake manufacturers.
klipschfan4life
Oct 19, 2007 03:19 AM
Method
Sep 9, 2006 10:24 PM
Bostonhoodhop
Aug 1, 2006 08:57 AM
Technician
Oct 12, 2005 09:23 AM
Cappelle
May 11, 2005 06:34 PM
