DIY how to remove 05 civic vp air intake
I did search and also read DIY but couldn't find the info. Can you guys help me?
thanks. |
RE: DIY how to remove 05 civic vp air intake
Welcome aboard!
The 7th gen guru (se7ensectoolate) should be by to help soon. But, it should be fairly straight forward. Try posting a picture of your engine bay, that will give me a better idea. |
good bye warrenty. dude dont be so hasty
I've been reading some of the basic mods, and ... I want to intall CAI. But, first I need to know how to remove stock air box (?). Some said, 01-05 LX,Dx are all same 1.7L engine...
Adding CAI will avoid warranty? |
whell first u have to locate it. if you look directly to the left there is a tubing to the left. follow that and use common sence. dont start wrenching until you have a plan for it. look it over. also turn on the engine. have your friend rev it. you can see and hear where its sucks in air.
ok i sell cars for a living....
adding any kind of performance parts that effect the way the car runs will void warrenty. this is a big mistake that most people make when buying a new car.... leave it alone. cause even if work needs to be done that is unrelated to the car. it will still be voided. this is how alot of big companies save there money whe dealing with customers that dont read fine print. wate for 60,000 miles. it sucks but i think thats what hondas new warrenty goes till. (i sell used honda and acura so i know a thing or two about them) |
ORIGINAL: dj_ipirate ok i sell cars for a living.... adding any kind of performance parts that effect the way the car runs will void warrenty. this is a big mistake that most people make when buying a new car.... leave it alone. cause even if work needs to be done that is unrelated to the car. it will still be voided. this is how alot of big companies save there money whe dealing with customers that dont read fine print. wate for 60,000 miles. it sucks but i think thats what hondas new warrenty goes till. (i sell used honda and acura so i know a thing or two about them) You have to be able to prove that his modification caused whatever problem is affecting the car. If it cannot be traced directly to the aftermarket part as the cause of the problem, than the warranty still stands |
true but all dealers will try to find anything to get out of warrenty work. that is a fact. there is proof all over the net. people getting f'ed cause they put in something aftermarket. mind you its only mechanical radios speakers and bodywork is not affected by warrenty
ORIGINAL: dj_ipirate true but all dealers will try to find anything to get out of warrenty work. that is a fact. there is proof all over the net. people getting f'ed cause they put in something aftermarket. mind you its only mechanical radios speakers and bodywork is not affected by warrenty |
ORIGINAL: Forty04 ORIGINAL: dj_ipirate true but all dealers will try to find anything to get out of warrenty work. that is a fact. there is proof all over the net. people getting f'ed cause they put in something aftermarket. mind you its only mechanical radios speakers and bodywork is not affected by warrenty |
