Do Exhaust Headers Increase Fuel Consumption?
By increasing the amount of exhaust that flows out of the piston (job of the header), is an exhaust header making the car use up more fuel by allowing more fuel to be taken into the piston upon intake?
Thanks
Thanks
RE: Do Exhaust Headers Increase Fuel Consumption?
There are some people that will tell you they get better gas mileage. Whether better or worst, it will be very very minimal and probably not even noticable. If it is a good design it should net you better gas mileage since you lower the exhaust restriction a bit, but not to much to lose the backpressure the engine needs. They are normally a few pounds lighter than cast iron ones as well. However, they are louders, so like mentioned above, you will probably lose the mileage due to the ill effect of stepping on it more.
Abdellatif
05-07-2013 12:46 PM
