DX cat question
Old May 28, 2007 | 11:51 PM
96civichb's Avatar
Default DX cat question
is what I'm looking at on the stock exhaust manifold (the part that looks like a large snake after having eaten a large animal), my catalytic converter? if it is, then by installing a header, would i have in the process, deleted my cat?
Old May 29, 2007 | 03:25 AM
Street Sniper's Avatar
Default RE: DX cat question
If it's on the manifold then, yeah that's the cat. If it's further down the exhaust you might be thinking baout the resonator. I believe with you 6th gen guys you just have to move the cat.
Old May 29, 2007 | 04:43 AM
cderalow's Avatar
6th gen DX/HX/LX have the catalytic converter integral to the header.
If you buy a header, please, have a high flow or regular cat welded into the stock mid pipe, it saves the environment, and I'd like my kids to have a healthy long life too. not to mention, it doesn't really increase performance
Old May 29, 2007 | 06:23 AM
96civichb's Avatar
Would my car likelypass DEQ without a cat?
Old May 29, 2007 | 11:28 AM
cderalow's Avatar
car will most likely not pass emissions without a cat converter.
honestly, if you've all ready got a catback system, changing from the DX to EX exhaust isn't that hard
Old May 29, 2007 | 04:36 PM
BlackDX's Avatar
Also if you relocate the cat, you will need to extend your O2 sensor wires to place them accordingly. The DX/HX/LX O2 sensors are right on top and bottom of the cat, with the EX/SI cat placement the O2 sensors are under/behind the motor....
If you're looking to get the most power out of the set up (reason to remove the cat) get a High flow cat, I read a test that showed the difference between a high flow and no cat being only like 5hp... high flow over oe was like 17hp....
Old May 29, 2007 | 06:32 PM
ej6buddy's Avatar
catless decreases performance of the engine
Old May 29, 2007 | 06:33 PM
FlipHKD720's Avatar
EX header,EX cat, EX catback exhuast (all from 96 of course), and you're all set on your exhaust system, yea the 6th gen DX's have the gay header/cat combo, but if you are just getting a header (and no cat-back) you can just get a cat welded into your exhaust system and be set for emissions
Old May 29, 2007 | 06:42 PM
FlipHKD720's Avatar
ORIGINAL: ej6buddy
https://www.hondacivicforum.com/m_279591/tm.htm
just to add to this statement i guess
Old May 29, 2007 | 06:50 PM
ej6buddy's Avatar
ORIGINAL: FlipHKD720
ORIGINAL: ej6buddy
in most cases...yes
in my experience...no
jjouet
May 22, 2006 05:07 PM
jusplayn85
Feb 24, 2006 08:17 PM
uk civhead
Jun 12, 2005 06:39 AM
fast93civic
Jan 5, 2005 11:05 AM
scottishpol
Dec 31, 2004 03:02 PM
