Exhaust problem
Old Jul 25, 2008 | 02:37 PM
megafandrew's Avatar
Default Exhaust problem
Why would my cars exhaust note change from loud as hell to much quieter and then when at idle I can hear the deep exhaust note sill but there is also a raspy sputtering/forcing air kind of noise coming from the mufflers as well. I listened for other leaks under the car but could not here anything. Is this possibly a muffler defect or could it be a duel n1 muffler setup causing this? (This is on a sr20det 180sx)
Old Jul 25, 2008 | 04:42 PM
Default RE: Exhaust problem
does it change to quiet while you are driving, or do you mean like one day it was loud and the next day it was quiet?
Old Jul 25, 2008 | 07:19 PM
hey nice del sol there yes it was loud the first few days i had it back, then it just seemed to get quieter, and now it has a wierd air sputter/rasp to it at idle only, instead of the deep tone it had before. Im not sure i think it still has the same amount of power though.
Old Jul 25, 2008 | 07:24 PM
air sputter seems it could be the engine pinging. might be an ignition timing issue. jump the service connector under the passenger side of the dash, check the ignition timing with a timing light and adjust as necessary.
Old Jul 25, 2008 | 10:19 PM
alright thanks sounds good, i notice the car has the sound of ticking lifters. I was reading the sr20 has vvt solinoid that nissan dealers can turn off, but ill look into your advice first. Time to do some research now, thanks again man
FRESH96
Dec 12, 2007 09:18 AM
pjstahl
Oct 2, 2007 03:51 PM
Bradical
Feb 5, 2007 12:41 AM
Rickimaru
Oct 31, 2006 07:12 PM
Froznface
Aug 3, 2006 11:56 AM
