exhaust rattling noise
Old Jun 1, 2008 | 04:02 PM
burgernuds's Avatar
Default exhaust rattling noise
hey i just installed a full catback greddy sp2, everything sounds great except when I'm stopped at a light I hear a rattling noise, but when I start driving again the noise is gone. It sounded really bad when I reversed slowly. I have a rear lip and it is touching the tip of the muffler, could this be the problem? I also hear nothing when I have it on parked with the engine on.
I think I might trim the lip opening a little bit more, but i don't want to trim it its not the problem. Thanks
Old Jun 1, 2008 | 04:43 PM
tknaub's Avatar
Default RE: exhaust rattling noise
it could be touching on your heatsheild...mine did that until i ripped it off.
Old Jun 1, 2008 | 05:19 PM
ej6buddy's Avatar
if it's a metal clanging, then it could be a loose exhaust connection, an unneeded heat shield, or if it's a softer sounding chatter, then it's the lip touching while the motor is at low idle due to the vibrations at idle or reverse.
Old Jun 1, 2008 | 05:43 PM
burgernuds's Avatar
where is the heatshield located at and do i really need it?
when you say loose exhaust connection, do you mean loose spring nuts?
it sounded pretty loud, but at times its louder than others and i remember several times I heard nothing while stopped at a light.
btw, is the vapors that come out of the muffler going to hurt my paint?
Old Jun 1, 2008 | 05:45 PM
burgernuds's Avatar
and it wasnt a metal clanging, it sounded like a knocking rattling noiserather... i might just cut the damn lip and see. thanks a lot
Old Jun 1, 2008 | 06:59 PM
ej6buddy's Avatar
most likely the lip then, just ask someone to back your car up or idle and go behind the car and check for yourself. sound rattles are never definite, that's why we have ears to check, lol
Old Jun 1, 2008 | 07:09 PM
you could also slightly bend the rear hanger alittle.... i wouldnt cut the lip IMO...
Old Jun 1, 2008 | 07:25 PM
KnightRiderCivic's Avatar
Yeah bending a hanger would much easier and less obvious to look at. Does your exhaust move much if you grab it and try to shake it? wait for it to cool down first lol...if so I would look at fixing that cause you never know what it could be rubbing against.
Old Jun 1, 2008 | 07:28 PM
ej6buddy's Avatar
yeah, double check the source before you cut anything. and it doesn't look bad with it cut if you do it right using the original body line as the cut, it just looks normal. if anything, you can just remove the lip if it comes to it.
Old Jun 2, 2008 | 05:38 PM
burgernuds's Avatar
well its a pain for me to remove the lip since i used a lot of tape originally, so just trimmed around the opening a little bit and now while idle on drive i hear nothing!! woot woot. But... when I reverse I still hear it. Does the muffler shave more violently when the car is reversing?? Could there be any other issue since it's not a metal rattling noise but rather a plastic knocking?
