Header wrap
Why do people wrap their header. To keep the exhaust hotter? Where do you get it.
RE: Header wrap
To keep the engine bay cooler...e-bay is a good place...I personally used it to keep my shifter from getting hot (short shifter too close to exhaust..)
RE: Header wrap
Header wrap is more or less like insulating your header. It keeps the heat in the header and away from the engine bay.
RE: Header wrap
yeah. asbestos wraps work best.
RE: Header wrap
Yea I wasn't sure. Header looks better without it but I guess if it helps, use it. Does the wrap keep ebay cooler than with stock x manifold without wrap? Thanks
RE: Header wrap
it keeps the bay cooler, so you are intaking cooler air, but it also keeps the exhaust hot, which in that article i posted shows that the hotter it is, the bigger it is, so the faster it moves, helping with that scavenging effect.
RE: Header wrap
on the DC sports ceramic or ceramic coated header the ceramic has the same effect as wraps...but some people say wraps work better than ceramic
RE: Header wrap
i did that on my bike, the exhaust is a lot hotter at the tip, but cooler down below, how much difference do you guys think i could expect on a car???
RE: Header wrap
I've never seen any numbers on header wrap temps, but remember, for every 10* you cool your intake air temp down- you will see a ~1% increase in Hp.
RE: Header wrap
So would buying this be worth the advantages? And does heating up your exhaust gasses actually help? I know hotter air is less dense so would that mean faster exhaust flow and less back presure?
