HondaCivicForum.com
-   Header, Intake, & Exhaust (https://www.hondacivicforum.com/forum/header-intake-exhaust-12/)
-   -   High Flow cat problem...... (https://www.hondacivicforum.com/forum/header-intake-exhaust-12/high-flow-cat-problem-28978/)
Impulse2k1 09-14-2006 09:25 AM
My girlfriends car is a 1998 Honda Civic EX 2dr coupe, it has a 4-2-1 header on it, a high flow cat and a catback. The problem is that there isn't an O2 sensor hooked up to the cat (universal kind without any O2 sensor wholes), and she has to go for emission testing soon. I know I have to make a whole and weld in a bung, but I dont know where to weld the bung for the O2 sensor. Should it be before the cat (by the two bolt flange)or right after the cat?
smit3413 09-14-2006 09:23 PM
RE: High Flow cat problem......
right after the cat...
Kedawei 09-14-2006 11:19 PM
Should be two O2 sensors, one before the cat and one after.
Impulse2k1 09-15-2006 03:02 PM
ORIGINAL: Kedawei
There is one in the header, so the second one that I need to put in should go after the cat?
phishy 09-15-2006 03:07 PM
Thats what it sounds like when I read it.
Kedawei 09-15-2006 05:03 PM
Yep, after it.
Impulse2k1 09-16-2006 05:16 PM
ORIGINAL: Kedawei
Yep, after it.
Awesome thanks guys
Chimera02EX 09-16-2006 05:19 PM
Try to keep it as close to the cat as possible though, you'll get better readings.
Pete 09-16-2006 06:38 PM
youre sure its a high flow cat not a test pipe?
Impulse2k1 09-17-2006 11:55 AM
ORIGINAL: Pete
I pretty sure it is a high flow cat, from what I gathered everything was purchased from ebay from the header to the catback and including the highflow cat.
