hissing sound
ive noticed that something under my hood is giving off a, louder somedays than others, hissing sound. It started shortly after i put in my intake i believe. Anyone know whats goin on? also I am quite a while over-due for an oil change, what kind of affect is that having on my driving? (like losing power or what?) thanks
Does the engine idle weird? If it idles any differently then it used to, then you've probably got a vacuum leak somewhere. But, my guess is that you just aren't used to the sound of the new intake. And change your oil you lazy ***.
Make sure you connected up your intake correctly and tighten it down good. And after a couple of thousand miles or months the oil starts to break down. When this happens the oil will not be doing a good job of protecting your engine. The oil lubricates and protects your moving parts of the engine, as well as help to transfer heat out of your engine. Get it changed now and do it often if you care about your car at all.
