i need more power! help please?
Old Nov 29, 2004 | 11:32 PM
nwhite82's Avatar
Default i need more power! help please?
i hav a 88 civic 4 door w b16a swap, aem fuel rail/fpr, skunk 2 cams,75 hp wet nos, jd timing gears, dc 4-2-1 header, custom 2 1/4 exhaust, aem cold air,msd ign./ coil and dist, field v-tech controller, what else can i do for some hp instead of turbo? i am only running a 15.2 sec 1/4 mile. my vtech controller is at 5000. should i lowerer it i have 18 inch rims , i know if i go back to 15 that will lower my times.
Old Nov 29, 2004 | 11:38 PM
sacicons's Avatar
Default RE: i need more power! help please?
is the 15.2 on the bottle? that is high either way. personally, it doesnt sound like a power issue. you should be pushing close to 225 WHP, that should be good for 13s. i would have to say its traction problems, even if you dont realize it, the tires can slip a little when you drag. i got some 14s with nt555Rs for the fronts, havent run em yet though. try either that or a better idea would be an LSD equipped tranny.
Old Dec 1, 2004 | 01:26 PM
niteryder's Avatar
traction, is the only problem you should be having. you should be dipping into the 14's every time you run. go with a 14 or 15 like sac said, and lower the tire pressure to around anywhere from 20-25 pounds. then you should be alright.
Old Dec 5, 2004 | 02:31 PM
XCM828's Avatar
Get smaller wheels like you said, and get your car tuned properly. A good tuning will help dramatically.
Old Feb 6, 2005 | 12:52 PM
Dickie's Avatar
Member
chip ure ecu, and have em upgrade u to a good feul map. that will make a differnence i think
Old Feb 6, 2005 | 01:09 PM
sacicons's Avatar
yeah, but the good fuel maps lean out the mixture to closer to stochiometric ratios, which is normally the best place to be, but if he is running on the lean side, where the power is (right on the brink of detonation) and he engages the nitrous, it could very well toast the engine.
Old Feb 7, 2005 | 03:26 AM
polo708's Avatar
ORIGINAL: Dickie
if your running cams and some of those other mods you listed, I pray that you already have ECU work done. Also, 15.2 is way too high for your setup... sounds like someone needs to take a trip to the dyno for some tuning.
Old Feb 8, 2005 | 11:25 AM
whitey0212's Avatar
well i guess u shouldnt of bought a civic then and wasted all your money
Old Feb 8, 2005 | 11:29 AM
Kappa22's Avatar
Ok, big man. What do you drive that gives you so much credit? If you drive a Mazda like your girlfriend blackmazda6s... talk about wasting money...
Old Feb 8, 2005 | 01:18 PM
Remmy's Avatar
ORIGINAL: whitey0212
Im not stomping on you but dude, were not here to knock people.
