Idling Problem
Old May 9, 2007 | 05:51 AM
soprano19's Avatar
Default Idling Problem
hey i have a quick qusetion... i put on a throttle body spacer, and it messed up the idel, now i took it back to where i bought the car and the said they replaced the pcv valve, and the idel control valve, now when idel its flx. in between 1000rpm's and 2000. they replaced both parts and its still having the same problem, couldn't it be the mass air sensor??? if you know anything HELP!!!!!!!
Old May 9, 2007 | 08:56 AM
StifflersMom's Avatar
Cat Fuсker
Default RE: Idling Problem
It's your spacer that's causing the problem. You will need to modify you throttle cable bracket so that there is some slack in the cable. Right now your spacer is basically pulling on your gas pedal
Old May 9, 2007 | 09:01 AM
soprano19's Avatar
no i know thats what i though, and we gave it the room it needed. i pulled off the spacer before i took it to the shop and it was still having the problem.
Old May 9, 2007 | 10:15 AM
Cat Fuсker
Here's what I'd do next. Get some silicone vacuum line and replace all of you vacuum hoses. It's only gonna run you $10. WHen you were messing there you could have easily distrupted one or two hoses and they get brittle and leak if you touch them.
Old May 9, 2007 | 10:18 AM
soprano19's Avatar
ok cool i'll try it out and keep you posted thanks.
Old May 9, 2007 | 12:11 PM
tha_next_Kobe's Avatar
What RPM should regular idle be?
Old May 9, 2007 | 02:08 PM
Cat Fuсker
just a tad bit under 1K
Old May 10, 2007 | 04:02 AM
soprano19's Avatar
yea the idle should be around 8-or 9hundred rpms
MD1032
Jul 17, 2007 10:26 AM
VinceDee
Jun 21, 2007 04:09 AM
blackmetal619
May 15, 2007 08:48 AM
bleedhondos
Dec 18, 2005 03:29 PM
tamda00
Sep 18, 2005 06:50 AM
