Injectors
I have 460 cc Rx7 injectors (low impedence) with a resistor box. When my car idles it goes up and down a little bit, and the previous owner todl me it was because the injectors. A friend of mine yesterday tried to fix my idle just by turning it up a little. Now my car idles at around 1300 but it doesn't go up and down as much. Every say 10 seconds or whatever the exhaust will make a different tone but quickly go back to normal. My friend told me its because I have mazda injectors on a honda and told me this is the reason my exhaust has a gassy smell to it. My car is turbo so I was told it's normal to run rich, how do I know if maybe I'm running too rich? My airfuel gauge isn't wideband so I don't have an accurate way to tell. Should I change my injectors? If I do what type of injectors should I change them to? I want the same size so it doesn't need to be tuned again, and should i get low impedence?
Thanks
Thanks
ORIGINAL: jason_guy_yeah
The injectors are too big. You could either chip your ecu and tune for the injectors or get 240cc high inpedence injectors and not need the resistor box.
and as for Mazda injectors, i've never heard of using them (not saying you cant do it, just never heard of it). RC injectors or DSM injectors (with a resistor box) and the norm i think. TunerToys i guess has some injectors as well, but DSM's, clips, and a resistor box can be had for like $75, which you cant beat.
^ it's cool, but stock injectors are 240cc themselves, and you're gonna need quite a bit more than that
as for your problem i couldnt really tell you man, i havent had any personal experience with tuning yet so idk about it. As for the resistor box, you dont necesarrily need the box, you just need four 10ohm 10 watt in-lineresistors to wire in there, but the resistor box cleans it up. I imagine you'll be able to use the one you have though.
Ok well thanks for your help. Maybe someone else knows, should I change out my injectors? Just to a different brand, same size though so I don't need to tune again? Something that people have had sucess with, but I'm only going to do it if people tell me it's something worth doing?
98brokeassvtec
Aug 23, 2004 05:31 PM
